Hello all i am happy to say that i have finaly finished putting in my edl.mani. and my new holly carb and thanks to some of the tips that i have seen on here i have accomplished my task. the truck runs great all i need now is a great set of headers for this 390fe. any good sugestions? they will be going on a 71 ford 250 campers special 2wd.
Well your right about the feeling Fomoko. i think i need to work on the kickdown rod it does'nt quite fit on there right it is kind of tight i added the extension peice that holley has for it. but its still hard to shift i am not getting out of second when i floor it. am i doing something wrong? i don't want to bend the rod it looks like someone had already bent it before. i wonder if theres an after market kickdown rod that i am sapossed to buy or something.
Best to talk to someone at a transmission shop or to drive down to one to get some ideas in setting it up properly. I have some idea but not that clear on proper adjustment.
The linkage has to be short enough not to bind between the carb/transmission when the gas petal is all the way up and long enough to activate second/passing gear when the petal is pressed down about 1/2 way to the floor. It will stay in passing gear if floored till you release pressure on the gas pedal. If the gas petal is to the floor the transmission will stay in passing gear which is second gear.
Good luck & hope this helps some what.
I cut the kick down rod and attached it at the swingset at the back of the manifold. Neither the Holley or the Edelbrock kickdown adapters looked right for my truck application. I'll try to find a picture. I know I posted one some time back.
As for headers, FPA is you have the funds. Otherwise, look at the FE engine forum and do a search for info on some of the cheaper brands like Hedman etc.
In the last motor picture on this page, you can see a shiny bolt/nut attached to the top of the swingset. It's where I attached the cut and flattened kickdown rod. sorry I can't find a close up picture. http://www.thedreyerfamily.com/69f25...50july2004.htm
Fomoko1 & GTex- Thanks for the info i will have to give that a try right now i belive it is real stiff and it needs to have a little play in it i will try it that way. and see if it shift correctly. then i will run over my nieghbors 68 cammero cause its such a nice car but he don't take care of it. Gtex are those pictures of your own truck if so that is a good looking truck. i will have to post you guys some of my truck here soon. thats if my wife ever gives up her digital camara.
