fuel filter question
Old Jan 20, 2006 | 04:34 PM
blueeyes2478's Avatar
blueeyes2478
Would this filter be good for my 7.3.
http://cgi.ebay.com/ebaymotors/Racor...31228405QQrdZ1
or this one
http://cgi.ebay.com/ebaymotors/racor...06448410QQrdZ1
Old Jan 20, 2006 | 07:30 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I think the 900FG would make a better pre-pump filter. You would want to swap the 1/2" flare nut fittings for some 5/16" or 3/8" barbed hose fittings to make it easier to install on a stock fuel system. That's a good price on that unit.
Old Jan 20, 2006 | 07:44 PM
blueeyes2478
Thanks cookie
but i already bought this unit,it looks good.Let me know what you think.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8031823919
Old Jan 20, 2006 | 07:59 PM
cookie88's Avatar
cookie88
FTE Emeritus
Looks good. I like that one too.
Old Jan 20, 2006 | 09:04 PM
DieselFuelOnly's Avatar
DieselFuelOnly
it seems to me that the transfer pump on our trucks would recirc more then 30 gallons per hour... Anybody have any hard numbers the flow rates of the fuel pump? How much is actually returned to the tank... hell, I bet I could BURN 30 gallons in an hour if i REALLLLY tried
I've been looking for a Racor unit like that with the heater, but they're hard to find at the higher flow rates.
Old Jan 21, 2006 | 04:07 AM
blueeyes2478
look on ebay,they had all kinds.
Old Jan 21, 2006 | 03:41 PM
blueeyes2478
Should i install the filter before the fuel pump or after it.
Old Jan 21, 2006 | 03:42 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
before. you want to keep everything running through the pump clean.
Old Jan 21, 2006 | 03:43 PM
guzzle92's Avatar
guzzle92
Pre-pump, just make sure it's rated for 'suction'. I don't think that many of the Racor's are rated for pressure.
Old Jan 21, 2006 | 04:59 PM
blueeyes2478
thanks guys,any other info that should know before i install this filter.
Old Jan 21, 2006 | 07:46 PM
cookie88's Avatar
cookie88
FTE Emeritus
Definitely pre-pump, that filter is not pressure rated.
I'm assuming you are also getting rid of the Q/D fittings while you're doing the filter installation? If not, you should.
Old Jan 22, 2006 | 04:20 AM
blueeyes2478
Yes i planed on getting rid of them also.
Thanks for all the help.
Old Jan 25, 2006 | 07:52 PM
blueeyes2478
What size fuel line do i need to replace the Q/D fitings and hard line.
Old Jan 25, 2006 | 10:00 PM
cookie88's Avatar
cookie88
FTE Emeritus
I used all 3/8" with two stainless clamps at each end.
Old Jan 25, 2006 | 11:38 PM
jtharvey's Avatar
jtharvey
5/16" will also work. I got the pre-pump kit from ITP and it came with a 5/16" hose. Like cookie said though, two clamps on each connection. One turned 180 degrees from the other.
