Hi. I have a 1992 Ford F150 4x4 5spd. It has 166,000 kms and I just got a tuneup. New plugs/fuel filter. And also got a new catalytic convertor n muffler/exhaust system because it didn't have one before. Sometimes the truck idles really high. Like 3-4000 RPM, while sometimes it idles normally. While I step on the clutch to shift you can hear it revving or if i put it into neutral it will be revving loudly. If I'm in a parking lot I have to touch the brake only as it moves by itself. Any ideas what could be the problem? It is intermittent and only does it some times. Thx.
Because of the intermittent nature, I would think it's not a vacuum leak. I would start by taking off the throttle body and cleaning it out really good with throttle body cleaner and a stiff brush. It could be sticking open sometimes.
I would also pull the codes to see if the computer can see something wrong.
I just checked the codes with a Ford code reader and it gave me code 11 which means "the system is ok". Would a dirty throttle body or a vaccum leak come up as a code on the code reader? Thx.
Theres on unplugged/broken hose under the hood. I'm not sure what it is/what is goes to. I'll attach a picture if you can help identify if this could be the problem.
That hose may go straight down. I believe it is one of two hoses that go into, and out of a charcoal cannister, that cannister should be just behind the radiator and below the battery( or passenger side/front of engine)
You want that hose connected, you have a vacuum leak.
Your vacuum reserve, the black coffee can looks rusted as well.
There may be pin-hole leaks in the vacuum reservoir, it has to be air-tight to hold vacuum. Be very careful with all vacuum hoses, they are plastic and break like dry pasta.
Search Seafoam on this site. You may want to seafoam the intake manifold, upper and lower plenums, before you take them apart, they are difficult to get in and out, and hard to clean even if out of the engine.
Stick with this site, this is the best place you will ever visit...if you want to keep that truck running well.
Looks like a PCV hose, I had one crack about the same place I took a piece of heater hose to couple it back together and it worked fine, that tube is very brittle though, It should connect to the air filter from a valve cover or other port through the actual crankcase valve. It could effect the idle, always fix the obviuous and the easiest first.
