Bronco II Ford Bronco II
transmission shift problems
Old Jan 20, 2006 | 04:08 PM
Carpo's Avatar
Carpo
Hi, I have an 88 bronco II that recently developed shifting problems. It is a Al4d auto trans....after getting it state inspected, I drove away from the shop and it would not shift to 2nd gear until i got up to 4000 rpms. while in auto or auto overdrive....manually shifting from 1st to 2nd is no problem at all. As soon as i put it back into drive....it drops back to 1st gear unless my rpms are high enough....A new vacuum modulator was installed after this happened to no avail. still having the same problem....trans fluid is right on level and red clean..can anyone help...thanks...Carpo
Old Jan 20, 2006 | 04:09 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site.
https://www.ford-trucks.com/forums/s...88#post3272088
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
Old Jan 20, 2006 | 10:32 PM
Monty06's Avatar
Monty06
have you changed the filter???
