Surging Trans.
Old Jan 20, 2006 | 03:37 PM
BHA's Avatar
BHA
Surging Trans.
I have a 2001 auto. when I start it on a cold morning the whole truck lurches forward even though it is in park. I've never had this problem on my other power strokes. Thanks BHA.
Old Jan 20, 2006 | 09:29 PM
Muktown's Avatar
Muktown
it sounds to me like your touque converter is partially locked is there any surging when you are driving it
Old Jan 21, 2006 | 08:42 AM
Casey's Avatar
Casey
It can't be the torque converter. If the trans is in park none of the clutches would be engaged, but the torque converter will still be turning the input shaft. If the converter clutch were locked it would turn the input shaft a bit faster, but it spins either way.
What is happening is that a clutch inside the trans is dragging a bit. It is not that unusual, and it doesn't hurt anything. You could have the trans rebuilt with bigger clearances in the clutch packs, or you could switch to synthetic MERCON fluid. Synthetic doesn't get as thick at cold temperatures so it won't drag on the clutches as much.
Old Jan 21, 2006 | 08:48 AM
maevans's Avatar
maevans
My truck does it every morning when its cold.
Old Jan 21, 2006 | 09:35 AM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Mine Does It When I Start It Up And Also When Turning It Off.
These Powerstrokes Just Want To Go. Go. Go.
