1978 - 1996 Big Bronco
Bronco Falling On Its Face
Old Jan 20, 2006 | 01:45 PM
sickboyclothing's Avatar
sickboyclothing
Post Bronco Falling On Its Face
I just bought a 1982 fullsize from a guy that was having a problem that everytime he would drive he would step on it and the bronco would just bog out.
He had the heads overhauled new timing chain fuel lines blown out replaced the carb. and intake manifold with a new edelbrock beefed up the ignition and still falling on its face i just popped the hood yesterday for the first time. my first attack is going to be the catalytic converter is this a good first ussumption or is there a better place to start please any feed back will help!!!!
Old Jan 20, 2006 | 01:53 PM
wlihntr's Avatar
wlihntr
could very well be a blocked cat, or a clogged fuel filter
Old Jan 20, 2006 | 01:57 PM
1970Custom's Avatar
1970Custom
I'd have to agree with wlihntr, check there first as I've had this problem on a couple other vehicles of mine.
Old Jan 20, 2006 | 01:59 PM
sickboyclothing
the fuel filter has been replaced
Old Jan 20, 2006 | 02:06 PM
seventyseven250's Avatar
seventyseven250
So you bought this rig from a guy who was having problems with it. You are gonna fit in just fine around here.
Oh yeah, I was going to say the fuel filter as well, but I was beat to it.
Old Jan 20, 2006 | 03:31 PM
jdmorg's Avatar
jdmorg
Give this a shot...
https://www.ford-trucks.com/forums/f...splay.php?f=44
It's the Big Bronco forums on this website. If there are more knowledgable Bronco owners out there, they're not on this website. The guys in there know it all up and down. Ask in there, and you'll definitely get some more responses.
Old Jan 20, 2006 | 04:06 PM
Bdox's Avatar
Bdox
Assume nothing and don't believe half of what you were told about the history.
Does the engine miss at any point? Can it pull a steep grade? Does it backfire through the intake or exhaust?
The cat could be a problem... check it out. Vacuum gauge.
Bogging is usually a fuel starvation issue unless it's also missing. If it misses then it's more likely an ignition problem.
Start with the tank, the fuel pickup, the lines, the filter(s), fuel pump pressure.
Old Jan 20, 2006 | 06:06 PM
big hoss 29's Avatar
big hoss 29
What kind of carb does it have and what's it's condition?
Old Jan 20, 2006 | 06:16 PM
big hoss 29
If the carb is too big for the motor, like a 750CFM unit, you might need to go to a smaller unit. If it's a 600CFM unit, it might just need to be fine tuned.I know from personal experience how hard it is to tune an Edelbrock, I own 3 of them and each one is more problematic than the previous one.
Old Jan 20, 2006 | 09:04 PM
Beast12's Avatar
Beast12
Originally Posted by jdmorg
Give this a shot...
Yep. Thread moved to Big Bronco forum.
-Matt
EbonyandIvory
Sep 15, 2013 10:37 PM
65sixbanger
May 12, 2013 10:22 PM
68 250 Flareside
Jun 27, 2007 04:59 PM
66flareside
33
Feb 23, 2006 10:50 AM
SumoBronco
Mar 22, 2003 03:03 PM
