oversize 9"
Old Jan 20, 2006 | 09:08 AM
blockheadbob's Avatar
blockheadbob
Question oversize 9"
I have a 9" third member out of my 78 F-150 that has a larger ring gear carrier and a larger pinion carrier than the 31 spline carrier I put back in. I had to get a new third member because I couldnt get a ring gear that would go over the carrier. I ordered the instalation kit from Jeff's Bronco and the pinion shims were about 1.5"s to small in diameter to fit the pinion carrier of the old third member. Any idea what I have got and how much stronger is it and is there a ring gear set for it?
Thanks,
Bob
Old Jan 20, 2006 | 10:20 AM
dinosaurfan's Avatar
dinosaurfan
oversize 9incher
BHBob, might you have a 9 & 3/8ths third member ? IIRC, Ford used a 9 & 3/8ths center section in the back of some of their larger cars. The bolt pattern is supposed to be the same as the regular 9 incher, but there are a couple of notches carved into the axle housing so the oversize gears can slip in. Other than that, I think it is almost all normal 9 inch stuff, strength-wise. The reason for the larger gearset was to make it easier to build a 2.75~2.50 ratio, I think. Hopefully someone here has a better memory than me. DF, @ his Dad's ( actually, on the boss' computer at work during lunch !)
Old Jan 20, 2006 | 11:32 AM
Mil1ion's Avatar
Mil1ion
Have you asked in the drivetrain forum where axle related topics are ?
