Aerostar Ford Aerostar
rear tailgate won't open
Old Jan 20, 2006 | 08:07 AM
oldmanbergie's Avatar
oldmanbergie
Question rear tailgate won't open
I have a 1995 aerostar van, and the outside handle for the lift gate wont work i went inside and looked for a inside latch or reliese nothing. The latch is free, like nothing hooked up. How do i get to open to make repairs??
Old Jan 20, 2006 | 08:42 AM
imabwithanitch's Avatar
imabwithanitch
tailgate
if you can take off the back hatch panel enough there is a rod inside that you can push down to open your latch. to repair the handle you have to put the end of that rod into the handle. good luck
Old Jan 20, 2006 | 09:17 AM
96_4wdr's Avatar
96_4wdr
after reattaching the actuator rod, lube with spray lithium grease all the moving contacts in handle release and lock mech...
attach a small nylon rope to bottom latch acutator and bring out thru pull strap hole...tie a handle in end to use as inside hand pull opener
Old Jan 23, 2006 | 07:49 AM
oldmanbergie
Thanks for all the help, got it working. I like the idea of inside pull, will do this before i reassemble inside cover.
[OLDMANBERGIE]
cabloom300
Apr 10, 2017 11:51 AM
RancherJV
Sep 25, 2016 07:32 PM
GuitarJesus
18
Mar 4, 2016 09:47 PM
r_reed
Jul 29, 2015 09:09 PM
FAST-FORD
Mar 25, 2008 07:43 PM
