Bad noises from Tranny
Last few days, I have a nasty "rattle" of some kind (sounds like something between a loose cat heat shield and bad bearing). Makes the noise most prominently when you rev it a bit in Park/Neutral, and when accellerating in lower gears. Also, you can hear it for a few seconds when you let off the power in any gear.
I did a fluid and filter change, the truck now shifts and accellerates fine but that noise is still pretty bad.
What does this sound like? I am fairly sure it's coming from the transmission. Input shaft bearing? Something else?
I should have dropped everything and done the fluid/filter right away. I am a bad owner. Good thing I don't keep pets. My backyard would look like a Stephen King movie.
I will try the ones on the truck now.
Thanks
