General Diesel Discussion
Favorite diesel engine
Old Feb 17, 2006 | 03:02 PM
  #46
kirmetja's Avatar
kirmetja
Second that on the VW TDI pulls mountain passes at 70mph VW service sucks though gladd my dad taught me how to wrench. wish I could get a f-150 with a diesel engine
Old Feb 17, 2006 | 11:23 PM
  #47
duramaximizer's Avatar
duramaximizer
that TDI is a sweet car, if i had to have a daily driver for long high mile daily trips to and from work. a TDI would be my pick. i would put a chip in that puppy and let'er eat.
Old Feb 18, 2006 | 08:55 AM
  #48
Kwikkordead's Avatar
Kwikkordead
I work on VW for a living.
You TDI owners would like to know that the intake manifold fills up with carbon and soot and it gets restricted pretty quickly. It's a fairly easy task to remove the manifold and clean it out. A bunch of 6mm allen heads hold it all together. Symptoms are a slightly reduced acceloration above 2000 rpm.
And if you get some bigger injectors those engines get a LOT more low end torque, and smoke as well.
Old Feb 18, 2006 | 10:12 AM
  #49
iwisha350's Avatar
iwisha350
444 & C7 Cat
Old Feb 18, 2006 | 10:30 AM
  #50
jessejames88's Avatar
jessejames88
3406B cat mechanical, hp = turn of the screw! go from 350hp and 600hp with a turbo swap and couple of turns on the fuel screws! RAW power under $1000
Old Feb 20, 2006 | 05:26 PM
  #51
JMac444's Avatar
JMac444
7.3L idi - 7.3L PSD.
Old Feb 24, 2006 | 10:53 AM
  #52
red92caddy's Avatar
red92caddy
generator
My favorite would be the new diesel tactical generator the the Military Special Forces uses. You can set it on a workbench right in front of you and you would not know it is running. The combustion actually takes place inside of the piston in order to help keep it quite. I'd love to have one for elk camp, but they run about $25,000 a pop.
Old Feb 24, 2006 | 12:18 PM
  #53
pioneer_plowboy's Avatar
pioneer_plowboy
have to be a IH DT-436 or a JD 6466
Old Feb 25, 2006 | 12:30 AM
  #54
lesmore49's Avatar
lesmore49
Dodge, Cummins 5.9 Diesel. Best diesel available in a pick up.
Old Feb 25, 2006 | 07:43 PM
  #55
04superduty's Avatar
04superduty
signature 600 N-14 Cummins, with a 18 spd behind it, in a kenworth t 800.
Old Feb 26, 2006 | 12:53 AM
  #56
rreynold's Avatar
rreynold
The Japanese built (Perkins licensed) 2.2 4 cylinder diesel, used in 1982-84 Mazda B2200 trucks and a few 1984 Ford Rangers. My '83 B2200, (purchased new) would get 35+ mpg on the road. Not fast but fairly torquey. Over 100,000 miles-two glow plugs and a fan clutch were only problems. Ran great when I sold it. If it had been in the larger Ranger I may still have it. Second owner put another 100K on it.
Old Mar 3, 2006 | 11:35 PM
  #57
hllon4whls's Avatar
hllon4whls
Is a t444e the same as our beloved 7.3 PSD? I was looking at the specs on the t444e and they dont look similar to the 7.3
Old Mar 22, 2006 | 07:46 PM
  #58
04superduty
yes the t444e is the same as the 7.3. just like the VT365 is the same as the 6.0. ford uses a different computer to make more HP, but less torque. most people only look at the amount of HP. not realizing you need the torque to get the weight moving.
Old Mar 22, 2006 | 11:21 PM
  #59
lesmore49's Avatar
lesmore49
If I was in the market, it wouldn't be a Ford PSD, or a GM Duramax, it would be a Cummins 5.9. I've never had a Dodge, but I believe the Cummins is the top Diesel.
Old Mar 25, 2006 | 05:32 PM
  #60
Fordteamone's Avatar
Fordteamone
CAT 3516B just because we operate with them. Ford 7.3
T diesel
Connecticut Chapter
67
Dec 9, 2018 09:19 AM
SDElwood
Michigan Chapter
Jan 16, 2017 11:46 AM
Patrick R.
General Automotive Discussion
Apr 4, 2016 05:24 AM
edtahaney
Jun 20, 2015 09:37 PM
jake00
The Next Generation
Nov 5, 2006 02:16 PM
