Sponsored by: Real Truck
Need Advice
Old Jan 19, 2006 | 02:58 AM
PREDATOR's Avatar
PREDATOR
Need Advice
I have a 98 150 SWB that is'nt rated to tow my 7500# travel trailer.
I have $20k to spend.
Should I get a 2004 F150 with 5.4 / 3.55 gears rated for 8600#.....or
Should I get a 2001-2002 F250 5.4 or 6.8.
I pull the camper 60 miles once a month and I will drive the truck 30 miles back and forth to work everyday . My concerns with the F250 is primarily gas mileage.. My concern with the F150 is I think they might be over-rating them as far as their towing and its effects on the future of the drivetrain.
Any opinions are greatly appreciated !!!!!
Old Jan 19, 2006 | 03:02 AM
BFR250SD's Avatar
BFR250SD
Go with the SD w/ the 6.8 and don't look back. If you can find it with 4.10 or 4.30 gears, even better.
Mileage wise, the 5.4 in an F250 is only 1 - 1.5 MPG better than the 6.8 overall, but that extra power of the V10 more than makes up for it.
Old Jan 19, 2006 | 04:06 AM
hadatoyota's Avatar
hadatoyota
Definetly the F250. I should get my new one at the end of this month. The research I did shows that if you want the truck to last, bigger is better. The mileage is not much different.
Old Jan 19, 2006 | 04:23 AM
BFR250SD's Avatar
BFR250SD
hadatoyota,
Welcome to FTE!
Old Jan 19, 2006 | 09:18 AM
caddofarmer's Avatar
caddofarmer
get the f250
Old Jan 19, 2006 | 12:51 PM
jgarza250's Avatar
jgarza250
F-250 no doubt about it!
Old Jan 19, 2006 | 03:59 PM
2003PSDF2504x4's Avatar
2003PSDF2504x4
I would buy the V-10
Old Jan 19, 2006 | 05:59 PM
PREDATOR's Avatar
PREDATOR
Thanks so much for the replys
I want to make a decision that I won't regret.
Can anyone tell me what to expect for gas MPG not towing and driving conservitivly (sp) with the 5.4 and 6.8
Thanks!!
Old Jan 19, 2006 | 07:54 PM
jake00's Avatar
jake00
you might get 1-2 mpg better with the 5.4.
with my v10 i get 11.8/13.8
I'd go with a 250
Old Jan 19, 2006 | 09:17 PM
yamahonda41's Avatar
yamahonda41
Man I would consider trading your 98 F150 or a 2001-2003 F250 with the 7.3L. My friend at work has a 1996 with 7.3 and 160k miles. Runs like new. He pulls a 24' race car trailer that I'm sure is 7500# or more and tells me he gets 16mpg towing and 18 not towing. Not sure I believe him but...
I have an F250 FX4 crew cab. My lie-o-meter shows 21+mpg at 65mph on the interstate. If I slow to 60mph it goes to 24mpg. Short trips around town and to/from work 2 miles I only get 14mpg. You said you drive 30 miles one way so I think the diesel would be a good option.
Has plenty of power when you need it.
