Steering Column
Old Jan 19, 2006 | 02:13 AM
GeorgiaJune's Avatar
GeorgiaJune
Steering Column
pulling apart my first 56 effie..i am stuck on the steering column.i have removed the clamp that locks it to the steering box,but it wont come out.any tricks to column removal???
Old Jan 19, 2006 | 05:45 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 19, 2006 | 07:36 AM
grncoup's Avatar
grncoup
take it all out at in one piece by removing the steering box from the frame.
Old Jan 19, 2006 | 07:44 AM
AXracer's Avatar
AXracer
The shaft inside the column is part of the steering box and is not detachable. The column can be removed from the shaft, but you must pull the steering wheel and then slide the column off the shaft. to remove the entire assembly grncoup is correct: remove the pitman arm and unbolt the steering box from the frame. Unbolt the floor plate from around the column and pull it out into the cab. Hang on for a couple more days for a new tech article on steering options to be added here.
Old Jan 19, 2006 | 03:54 PM
51ford fan's Avatar
51ford fan
Welcome to the forum, There has been several guys on this forum in the past that have had that same problem. They wound up cutting the outer column at the floorboard and sliding it off the center shaft then later they welded it back together.
Hope this helps
Rod 51F1
Old Jan 19, 2006 | 04:15 PM
AXracer's Avatar
AXracer
Hope this helps
Rod 51F1
That would really be the hard way. see above.
Old Jan 19, 2006 | 07:20 PM
LEckart's Avatar
LEckart
welcome georgiajune-
When you get a chance setup a gallery so we can see your truck. Keep asking the questions as there are many answers here (most of them good ones,lol).
