Foot emergency Brake
Old Jan 18, 2006 | 10:08 PM
jav409's Avatar
jav409
Would like to convert the hand brake in my 66 to a foot type brake. has anyone done this ? and if so what year did you get one out of and did it bolt in ?
Thanks - Jav
Old Jan 18, 2006 | 11:58 PM
mikeescott's Avatar
mikeescott
I have been looking at a new Lokar setup.
I don't know of anything that will bolt into place though.
Old Jan 19, 2006 | 12:40 AM
pootscratch89's Avatar
pootscratch89
Lokar sells a custom billet aluminum foot brake for about $150.
Old Jan 19, 2006 | 01:11 AM
ford390gashog's Avatar
ford390gashog
get the setup from a 73-79 ford truck. it mounts with 6 bolts. drill 4 holes in the firewall and mount it. the other 2 bolt to the bottom of the dash.
Old Jan 19, 2006 | 08:09 AM
jav409's Avatar
jav409
Thanks for the info
Old Jan 19, 2006 | 08:32 AM
garbz2's Avatar
garbz2
Trapper did this conversion over at Slick 60s used a 79 unit and attached it to the kick panel
Garbz
Old Jan 19, 2006 | 08:35 AM
garbz2's Avatar
garbz2
Trapper at sli<!-- -->ck 60s did this modification using a 79 assembly and attached it to the kick panel. looked pretty simple. the floor pan stayed basically the same from 65 to 79.
Garbz
Old Jan 19, 2006 | 01:42 PM
Customcab's Avatar
Customcab
I guess you'll lose your drivers side air vent if you mount to kick panel?, Also how much clearance for verison from a 73-79 model with the floor & dash mount type e-brake for air vent?
Mitch
