Gear box lube
Old Jan 18, 2006 | 12:07 PM
IM1096's Avatar
IM1096
Question Gear box lube
I'm getting ready for the Spring MX race season and I do a lot of towing during that time, (toy hauler with dirtbikes). I want to change the fluids in my 6 speed manual, transfer case and the differentials. What is the best lube for these boxes?
Old Jan 18, 2006 | 01:45 PM
IM1096's Avatar
IM1096
No input????? I guess I'll trust the guy's at Jiffy Lube...... NOT!!!!!! I'm going to call a local Tranny shop and see what they recommend,,,,,,,,,,,,
Old Jan 18, 2006 | 02:08 PM
SpringerPop's Avatar
SpringerPop
Patience, Grasshopper-sohn. It has only been an hour and a half.
A synthetic oils guru will happen by shortly and fulfill your request with more than you will want to know. Be trusting.......
Pop
Old Jan 18, 2006 | 02:32 PM
IM1096's Avatar
IM1096
I know SpringerPop,,,, but I love working on my truck. My girlfriend thinks I love the truck more than her...... (at least she knows ) I'm at work, trying to focus on the job,,,,,,,, but I can't stay away from FTE to long, I get all jittery. I can wait for the info,,,,,,,,,, I know somebody will steer me in the right direction By the way, my Springer pretty much rules the roost at my house, how about yours?
Old Jan 18, 2006 | 02:38 PM
Kwikkordead's Avatar
Kwikkordead
I use Redline in my six speed. There are three choices for the transmission.
D4 ATF
High Temp ATF
MTL if you want some extra heavy duty lubrication. NO thicker than that! Ford wants us to use ATF in the six speed, but MTL is thin enough to run in the stick shift without problems. I use it myself and the shifting is like butter and ZERO gear clash.
For the rear axle I use Redline Shockproof Heavy 75-140. I do not have a limited slip.
Old Jan 18, 2006 | 02:43 PM
ford390gashog's Avatar
ford390gashog
ford specs mercon ATF for the 6 speed and t case. the front diff gets 80w90 dino oil the rear gets 75w140 synthetic gear lube( add the friction modifier if you have l/s).
Old Jan 18, 2006 | 02:55 PM
IM1096's Avatar
IM1096
Thanks Kwikk, it looks like you tow a little bigger trailer than I do. I'll check into the Redline products.
Old Jan 18, 2006 | 02:57 PM
IM1096's Avatar
IM1096
Thanks for the input ford390,,,, I want a little better than Ford spec as I tow a pretty heavy trailer.
Old Jan 18, 2006 | 03:00 PM
ford390gashog
whats in there now?
Old Jan 18, 2006 | 03:11 PM
IM1096's Avatar
IM1096
ATF in the trans and transfer, not sure what weight gear oil in the differentials. I had it done last year at a transmission shop before hunting season.
Old Jan 18, 2006 | 03:19 PM
ford390gashog
being that the ford spec fluids have taken your truck this far i really don't see a reason to use anything else.
Old Jan 18, 2006 | 03:25 PM
IM1096's Avatar
IM1096
I didn't do much towing prior to last year, I just want to make sure I'm using the best products for my application. Thanks for your opinion.
