How to get boost up
Old Jan 10, 2006 | 09:39 PM
kennedyford's Avatar
kennedyford
Red face How to get boost up
Ive posted a couple time with questions and here is what ive found.
I have no idea what stock boost will read on a 2000
An exhaust leak will get those temps up and keep the boost in teens.
The most I can get with a 75hp chip and a 6gun tuner is 22.
And now a new culprit, the ebpv came on when cold and I can hear a high pressure leak somewhere near the pass battery. Leaks leaks everywhere......argggg. Anyway where are those neat tube replacements or the rubber high pressure tubes. I like heatstrokes pictures. I believe Kwik or cookie 88 will lead me to my salvation.
Old Jan 10, 2006 | 09:45 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
stock boost should be 15-17 psi in the most stressful conditions, with the wastegate activated. unplugging the red line will maybe raise a peak boost 2-5 pounds.
the hissing noise is probably from the EBP sensor (exhaust back pressure). it is attached to the front most part of the right side exhaust manifold. get under the truck and look up, there should be a small tube coming up. there is a sensor on the end and this is where the boost is probably leaking. the EBPV creates up to 20psi restriction between the valve and manifolds, so alot of the exhaust is probably going out of this leak.
Old Jan 10, 2006 | 10:40 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Strokin_it's got it....if you're hearing an exhaust leak at the passenger side battery it is most likely the exhaust backpressure sensor tube.
Old Jan 11, 2006 | 11:25 AM
Kwikkordead's Avatar
Kwikkordead
Yeah, find and fix any leak that you can. Also remove the pressure line from the wastegate control valve where it goes into the Y-pipe. Disconnect both the green and the red lines from the canister and from the rubber air boot. Plug the hole in the boot. Adjust the spring tension tighter on the wastegate control rod. Take the Y-pipe out of the engine, the intercooler tubes out. Completly degrease all the blue and the orange boots. Clean and degrease all the tubes and y-pipes. If you have time and have not already done it, do the CCV mod. Put it all back together, leaving the wastegate control hose disconnected. With that 75 HP chip you should get at least 27+ PSI of boost at WOT 2500 RPM.
Old Jan 11, 2006 | 08:09 PM
kennedyford
Ahh what I needed to know, so that tube may poss be leakin. And thanks kwik, I pulled the red and plugged it but I didnt know to plug the green also. CCV mod is next.
Old Jan 11, 2006 | 08:10 PM
kennedyford
O by the way, is there a cheaper way to replace those blue or orange boots?
Old Jan 11, 2006 | 08:17 PM
cookie88's Avatar
cookie88
FTE Emeritus
No...all the replacements I've seen are pretty spendy. Are you haveing a problem blowing the boots off? You don't really "need" to replace them if you aren't, unless they are damaged.
Old Jan 11, 2006 | 10:43 PM
Kwikkordead
Just so there is no misunderstanding: There are a total of three vacuum ports for that wastegate control solinoid. Plug 'em all. Every little bit leaking out = loss of boost.
Old Jan 12, 2006 | 08:19 AM
7.3HAIRDRYER's Avatar
7.3HAIRDRYER
Go find a local hydraulic hose store. They sell the silicone impregnated boots in any length. Some of those cost near $26/foot, but you only need about a foot or so.
4-Star Hose
Pyrtek
etc.
Formerly BUICKTURBO
Old Jan 16, 2006 | 01:32 PM
kennedyford
Once again Kwik to the rescue
Silly me left the ebv line off the manifold when I finished milling the manifold, Big!!!!!! exhaust leak. Fixed it and followed Kwiks advice and pulled all lines red and green and made a schnazzy plug and bypass. The end result is hard to keep the tires from spinning on setting 6, but Im still not getting any higher than the 22 or there abouts boost. Spools up quick but now do I need a blow off valve?
Old Jan 16, 2006 | 01:33 PM
kennedyford
[QUOTE=7.3HAIRDRYER]Go find a local hydraulic hose store. They sell the silicone impregnated boots in any length. Some of those cost near $26/foot, but you only need about a foot or so.
4-Star Hose
Pyrtek
etc.
thank you for that info.
Old Jan 16, 2006 | 01:44 PM
PSNut's Avatar
PSNut
Check the Y pipe.
Make sure there are no imperfections and bumps on the y pipe boot mating surface as this will cause a leak no matter what...u can grind down imperfections easily to provide a smooth good sealing surface with the boots.
Nut
Old Jan 16, 2006 | 02:05 PM
PowerstrokeJunkie
Due to the nature of a diesel, you do not need a blow off valve. there is no throttle plate that restricts the airflow when the throttle is closed. the only restriction between the turbo and the cylinders is the intake/exhaust valves. you'll never see a diesel with a blow off valve, as the amount of fuel injected controls the engine speed.
Old Jan 16, 2006 | 03:18 PM
kennedyford
I was wondering because of the noise it makes when I get off the throttle and also the chittering this truck makes when about 18 lb of boost and a shift. It almost sounds like the blade is cavitating. Hmm. I have the 6637 and ww.
Old Jan 16, 2006 | 05:59 PM
cangim's Avatar
cangim
when you did the WW, did you check the turbo for play? Sounds like everything is tight. You might fashion some type of jig to actually pressurize the intake side and see if there are any leaks that you are missing or not hearing when the engine is on. I have a pre 99 turbo, smaller than what is used on 99+ and can easily make 26 lbs.
On another thought, is the wastegate seating down properly/all the way? If it is not fully closing off that would definate lead to some loss of boost.
