Engine Mounts
Old Jan 18, 2006 | 11:39 AM
C. Lee Colbert's Avatar
C. Lee Colbert
Engine Mounts
OK, So I had the transmission fixed, it runs like new...but 1 of the motor mouints is bad...and a place I called in town here wants $300~350 to replace them both.....is it that hard to do, is this something I should be able to do myself? I have never done this before, but I am willing to try...any help?!
Old Jan 18, 2006 | 11:54 AM
Flatbed392's Avatar
Flatbed392
C. Lee,
It is just a matter of disconnecting the battery, removing the starter, unbolt the mounts, and jack the engine up far enough to clear the mounts and switch them with the new ones.
Damn !!! I would do them all day long every day for 350 bucks a pop !!!
Don
Old Jan 18, 2006 | 12:17 PM
olfordsnstone's Avatar
olfordsnstone
Just be careful to ensure the engine is secure before you stick your fingures and hands around that area. If your jack gave while you're in there, you might find you would have been better off paying all that money.
If precautions are taken, it's not a bad job to do. Certainly worth saving $350.
Old Jan 18, 2006 | 12:25 PM
1975Ford's Avatar
1975Ford
Loosen the nut and washer under both of the engine towers, and jack up the engine as Flatbed392 mentioned. Then loosen and remove the bolts which hold down the engine mount.
Old Jan 18, 2006 | 12:57 PM
Mil1ion's Avatar
Mil1ion
If it's 460,there is more to it that above.
Btw Lee, I am having a hard time reading the text in your albums due to the upper case.
Here is site to change it to lower case easily if you wish to consider it.
http://www.spellcheck.net/
Just copy<> Paste<> change text <> copy <> then paste it back.
Good luck with the mount change.
Old Jan 18, 2006 | 02:16 PM
77effie's Avatar
77effie
the stupid question of the day !!!!!!!!!!!!!!!!!!!!!!!!!!
will i have to change the frame mounts to swap from 400 to 5.0 , i already have the mounts that attach to the motor
Old Jan 18, 2006 | 04:13 PM
C. Lee Colbert
it is a 302, and I have a bad habit of using upper case...(my son always sez : "stop shoutin!")
Old Jan 18, 2006 | 04:38 PM
1975Ford's Avatar
1975Ford
Awe, 302 cid, You should be able to tackle this project. If you have a car lift, it will be an easier task to tackle. Do you know if it is the driver side motor mount (left side mount) or passenger side motor mount (right side mount).
Old Jan 18, 2006 | 04:48 PM
tjc transport's Avatar
tjc transport
i ain't rite
yup. what the others said. a block of wood, a GOOD floor jack, and a few wrenches. should take no more than 1 hour for both, and thats with a beer break. the trick is to break all the bolts loose, and sometimes i take them out before jacking the motor up. once it is up and the new mounts on but not tight, i let it down, aligning the mounts to the towers, set it in place, and tighten everything up.
Old Jan 18, 2006 | 04:51 PM
1975Ford's Avatar
1975Ford
Welcome to forum, There is never a stupid question, Here an article https://www.ford-trucks.com/forums/s...towers+400+cid
Old Jan 18, 2006 | 05:04 PM
77effie's Avatar
77effie
killer .....thanx
Old Mar 12, 2006 | 11:28 AM
C. Lee Colbert
well, I found a place in Tinton falls NJ to swap out my engine mounts...and for $40....they did a great job. And next they are gonna do my gas tank! These guys are BIG TIME OL' FORD truck fans! The owners son is building a Bronco from the ground up, and putting a turbo charged Cummins diesel in it...it's gonna be a real beast!
Old Jun 14, 2006 | 02:53 PM
slothshady's Avatar
slothshady
well... im currently in the process of changing out the passenger side mount... we put the new one in and nothing will line up, it is too big. the fan blade is so high that it would slice the top radiator hose. do u guys know why this might be happening, and a fix for it?
thanks
Old Jun 14, 2006 | 03:02 PM
77effie's Avatar
77effie
slothshady ..... which motor ? are you changeing frame mount or motor mount
oh btw
i ended up haveing to cut new slots in stock 400 mounts about 3/4 inch behind the original ones and plug weld the old ones up in order to drop the windsor motor in place of the 351m/400
Old Jun 14, 2006 | 03:35 PM
slothshady's Avatar
slothshady
sorry.... 77 f250, 300ci, 2wd.
and we are changing the motor mount.
