Sponsored by: Auxito
Electrical problems
Old Jan 18, 2006 | 10:11 AM
weebles63's Avatar
weebles63
Unhappy eltricle problem wipers,power windows,dome light
Hello everyone . Im a new member and im not a english major so bare with me I have a 2000 f 150 with 100,000 miles recently my wipers and power windows and dome light quit. checked all fuses and changed relay to wipers. I went to auto zone to get help the guy was as puzeld as i am.He put it on the code scaner and it didnt read anything the scaner was blank wouldnt even fire up HELP THANK YOU JEFF
Old Jan 18, 2006 | 11:13 AM
KingRanchMan02's Avatar
KingRanchMan02
Check out "2002 Electrical Problem" in another thread from today. Similar problem and BillyBob69's reply.
Originally Posted by BillyBob69
Check around and behind the main fuse panel on the drivers side firewall inside the cab. These trucks have been known for a leaky windshield and water tends to pool up around that fuse panel causing all sorts of wierd probs.
Old Jan 18, 2006 | 11:27 AM
weebles63's Avatar
weebles63
thanx king , dont see any water or damp carpet
Old Jan 18, 2006 | 08:53 PM
steve(ill)'s Avatar
steve(ill)
not much help, but i dont see anything the wipers, door windows and light have in common except common harness at the fire wall or out of fuse box like KingR says.
Old Jan 19, 2006 | 07:23 AM
projectSHO89's Avatar
projectSHO89
They all have connections to the GEM module.
Steve
Old Jan 19, 2006 | 02:30 PM
weebles63's Avatar
weebles63
thanks steve. today i took the dash apart and exposed the fuse box i turned the heat up and after about 20 minuts the fuse box started clicking and the wipers came on and off so i think the gem moduel meybe shorting or may have goten wet . witch is posible because we have had rain and snow lately . now if i can figure out how to get to the moduel i think i will be in luck. i took the 2 nuts and 2 bolts off of the box but it is still atached smehowthanx jeff in indiana
Fyrfyghtr
Oct 28, 2016 06:36 PM
Yedra
1997 - 2003 F150
Sep 9, 2016 11:20 PM
Redworks
Apr 17, 2016 04:48 PM
slandry
Feb 24, 2016 11:52 AM
CUMINSLOW
New Member Introductions
Oct 6, 2015 10:34 PM
