what gears I got?
Old Jan 18, 2006 | 01:12 AM
Caleb1's Avatar
Caleb1
what gears I got?
I have an 84' f-150 2wd 6 cyl 4 speed od manual. 8.8 rear.
will someone please tell me what gears I got? thanks.
axle code B
Thanks.
Old Jan 18, 2006 | 04:15 AM
Dungeon_Master's Avatar
Dungeon_Master
There should be a number with the letter B. Here is the list I have.
Limited Slip:
Code Man Size GVW Gear Ratio
B2 Dana 60 5300 4.10
B3 Dana 5300 3.54
B4 Dana 5300 3.73
B5 Ford 5300 4.10
B7 Dana 3.73
B6 Dana 3.55
Old Jan 18, 2006 | 05:45 AM
DT 466Man's Avatar
DT 466Man
If its an F150 with an 8.8 it should have a 3750lb load rating.
those numbers above are for 3/4tons and 1 tons.
3.08 open should be 18
3.55 open should be 19
3.08 LS is H8
3.55 LS is H9
or there should be a tag on the rear axle on one of the pan bolts that has all the info and axle ratio.
DT
Old Jan 18, 2006 | 07:03 PM
srercrcr's Avatar
srercrcr
I have the same setup, with a 3.08 axle.
It turns 1600 rpm at 60 mph.
Do the math.
Old Jan 19, 2006 | 08:55 AM
Caleb1's Avatar
Caleb1
It says b17...what is that?
Old Jan 19, 2006 | 09:38 AM
oldhalftons's Avatar
oldhalftons
are you sure its not transmission code B (4speed overdrive) and axle code 17?
thats a 8.8 with 2.47s
nothing I have shows B17 in 80-86
Old Jan 19, 2006 | 09:56 AM
Icicle's Avatar
Icicle
Do the math.
Yuck
That would put you at 1650 RPM at 60 MPH with 30 inch tires........ Assuming a final drive ratio in 4th gear of 1:1 which, with an overdrive, its probably not 1:1, so your probably spinning less than that...
I thought I had it bad
Old Jan 19, 2006 | 11:31 AM
Caleb1's Avatar
Caleb1
Thanks guys that's it. axle code 17. No wonder this thing slugs off the line....but it does get good gas mileage, though. But then I have to slip the clutch a little and I keep burnin 'em up. Oh, I have 27 by 9 tires.
Thanks guys.
