Sponsored by: Real Truck
Clunk
Old Jan 17, 2006 | 09:58 PM
DELBERT's Avatar
DELBERT
Clunk
Well I found out the problem every time I would hit the brakes had a loud clunk in the front end both lower ball joints were waisted gonna replace all 4 with moog truck only had 35000 miles
Old Jan 17, 2006 | 10:30 PM
BFR250SD's Avatar
BFR250SD
Plow........that'll do it real quick on these trucks. Make sure you get the greaseable joints and you'll be all set.
Might want to peek at your front wheel bearings while you're in there.
BFR
Old Jan 18, 2006 | 10:28 PM
DELBERT's Avatar
DELBERT
got it done if anybody needs the part numbers for some greasable ball joints from moog they are K8607T for the lower and upper is K80026 FOR A 2000 F350 4X4 V-10
Old Jan 18, 2006 | 10:34 PM
jake00's Avatar
jake00
did you do it yourself?
Old Jan 19, 2006 | 08:39 PM
DELBERT's Avatar
DELBERT
yes I did saved about 400 bucks
