Thermostat housing...
Old Jan 17, 2006 | 07:19 PM
wickymustang's Avatar
wickymustang
My housing is leaking on my 1995 F150 with the 6 cyl and I am about to change it, are there any tips or tricks as far as the pipe fitting that comes in from the passenger side? Should I get a new one and housing instead of trying to get the old one to seal up again?
Old Jan 17, 2006 | 09:34 PM
havi's Avatar
havi
I'll have the Roast Duck
buy the pipe...IMO it's worth the extra. They tend to rust in there pretty good.
Old Jan 17, 2006 | 10:26 PM
300 4 ever's Avatar
300 4 ever
Yes, buy a new one, I think they are around 10$. They are heavier in construction and seemed to have a better sealing surface.
Old Jan 17, 2006 | 10:39 PM
brownstraightsix's Avatar
brownstraightsix
I changed my housing this morning. I unscrewed the pipe right at the fitting, took the whole issue inside on the work bench. I put the housing in the vice and unscrewed the fitting. She was tight but she came. I put it back like it was and my temperature gage has never been so high, so it worked. So if you dont get a new fitting, it's absolutely possible to use the old one.
diehardstroker
22
Nov 21, 2013 06:58 PM
GruesomeJeans
Washington Chapter
41
Oct 13, 2013 04:52 PM
barely alive
Mar 8, 2013 01:48 PM
RRranch
13
Mar 25, 2009 05:22 AM
bubbaredneck
Feb 6, 2002 07:58 AM
