200k !!!!!!!!
Old Jan 17, 2006 | 06:39 PM
barebackjake's Avatar
barebackjake
200k !!!!!!!!
hit 200k on my way home today.....
Old Jan 17, 2006 | 07:13 PM
jcab's Avatar
jcab
congratulations, any tranny repairs in those 200k miles? Or other major problems?
Old Jan 17, 2006 | 07:19 PM
Kwikkordead's Avatar
Kwikkordead
Do we all get a cigar? Congratulations on a job well done.
Old Jan 17, 2006 | 07:20 PM
Brians97F250Crew's Avatar
Brians97F250Crew
Congrats!!! .... I have like 28k more to go ... I'll be there this year hopefully without any further issues.
Old Jan 17, 2006 | 07:28 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Nice. Gotta love a high milage hot rod diesel.
Old Jan 17, 2006 | 08:08 PM
barebackjake
nope just 3 clutches.....getting time for a tranny though synchros are pretty worn and bearings starting to get a little loud over 3k rpm's lookin for a good deal on a 6speed and tcase.
no real huge problems over the 200k, worst one was a lifter stuck bent a couple pushtubes, had to pull head to fix the hold down. that was about 150k miles
this is acutally not the original motor though i had another motor in it before this one when i still had my 95 dually. i had 530 hybrids, h2e turbo.....500+ hp and i had a valve float, piston bent valve and when it came back up again it cracked the head at the valve guide and broke the piston. i sold the motor complete with injectors and turbo, and trade for a stock motor since i was wanting to sell the dually since it was 2wd i wanted to be able to tow my horse trailer with the 97 i needed a more mild forgiving setup. so im running a much more mild setup, but still pushing the 400hp mark with daily driveability and towing ease. this motor has about 170k on it.
now i just gotta finsh getting the 05 front end on the truck.....
Old Jan 17, 2006 | 08:21 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yeah!!!! Coil springs rock! by old Bronco rides so much better than the 250 does, it's no comparison.
Old Jan 17, 2006 | 08:24 PM
1997F-350's Avatar
1997F-350
sweet man...i hope mine gets there with nothing major. got about 70k more to go for that though.
Old Jan 17, 2006 | 08:31 PM
barebackjake
no coil spings.......radius arms yes....the factory spring buckets and the radius arms makes it real easy to air bag the front....jost working out some engineering issues with axle to radius arm brackets since the obs D60 driverside axle tube is shorter than the SD theres not as much steel to weld the brackets on so i have to make them bolt on around the tube and leaf spring perch. i dont trust welding to the cast on the pumpkin. nor do i wanna tear the axle down just to do it.
ill have pics up when its all done
Old Jan 18, 2006 | 12:17 AM
chapguy's Avatar
chapguy
Congrats, bbjake. Take care of the truck so you can take care of those fine horses! See ya back here again in 100K!
