Brake Lights out, please help!!
Old Jan 17, 2006 | 03:38 PM
dzhix's Avatar
dzhix
2002 Ford Explorer Sport Trac
For some reason my brake lights have gone out, and I thought it would be a simple fix.
  • checked the fuse and they are OK
  • replaced the bulbs
  • replaced the brakelight switch
The brakelights still won't work, but the turn signals still function properly. I have had a problem with the turn signal **** before, where the right turn signal would blink fast with the tilt steering in a certain position. not sure if this is a related problem, but any advise is appreciated.
Recently changed the brake pads but I can't imagine anythng that could have caused this.
Old Jan 18, 2006 | 04:08 PM
Franklin2's Avatar
Franklin2
Does the high mount brakelight work?
