No Brake Lights!! Help Please!!
Old Jan 17, 2006 | 08:55 AM
dzhix's Avatar
dzhix
For some reason my brake lights have gone out, and I thought it would be a simple fix.
  • checked the fuse and they are OK
  • replaced the bulbs
  • replaced the brakelight switch
The brakelights still won't work, but the turn signals still function properly. I have had a problem with the turn signal **** before, where the right turn signal would blink fast with the tilt steering in a certain position. not sure if this is a related problem, but any advise is appreciated.
Recently changed the brake pads but I can't imagine anythng that could have caused this.
Old Jan 17, 2006 | 06:39 PM
JerrySimm's Avatar
JerrySimm
What Vehicle?
Old Jan 18, 2006 | 05:18 PM
maa139's Avatar
maa139
Is the bl switch adjusted properly? Is it actually being engaged when you step on the pedal?
