351w transmission
Old Jan 17, 2006 | 10:49 AM
Rupenthal94F150's Avatar
Rupenthal94F150
351w transmission
I'm planning on doing an engine swap from a 302 to 351w. I am going to need the flexplate for a 351w that will fit on a 4R70W/AODE transmission. I am having trouble finding this 351w/4R70W tranny combo to get the flexplate out of. If anyone knows if this combination ever existed please tell me. Getting this part is crucial to the engine swap or else it may not work out.
Old Jan 17, 2006 | 12:19 PM
mikeyswood's Avatar
mikeyswood
I have a flex plate from a 96 e250 351. I do not know what tranny it had, but if you know of any identifing marks, I can give it a peek.
Mike
Old Jan 17, 2006 | 01:24 PM
gatesj's Avatar
gatesj
I don't think they put that box behind the 351, only the E4OD. But I could be wrong.
Old Jan 17, 2006 | 04:30 PM
Rupenthal94F150
If the 5.8L/4R70W combination never existed, could the swap still be possible?
Old Jan 17, 2006 | 08:53 PM
gatesj's Avatar
gatesj
The engine management for the 351/E4OD combo controls the E4OD also. You you ran a carbed 351 or a 351 with engine management for a standard transmission (F-250 or above) I would think you might be able to get it to work. Although the 4R70W might be computer controlled.
The reason they didn't put the 4R70W behind it was the torque from the 351 is more than what the 4R70W is rated for, I think.
But again, I am not sure. I know they ONLY transmission they put behind the 351 was the E4OD in later years, the 4R70W came behind the 302 in certain cases.
Old Jan 18, 2006 | 07:25 AM
Casey's Avatar
Casey
The 4R70W is computer controlled.
Old Jan 18, 2006 | 08:51 AM
gatesj's Avatar
gatesj
You won't find a Ford PCM for 351 and 4R70W... You'd have to get separate or custom controllers, I think there are companies out there that make computers to just control the transmission but it will be pricey. Better off to spend the money and put the right transmission in, the 4R70W is good for 700ft/lbs of torque, the E4OD (4R100) is good for 1000ft/lbs.
Old Jan 18, 2006 | 09:45 AM
Casey's Avatar
Casey
And both of those torque ratings are after the torque converter, which can multiply engine torque by 2:1.
Old Jan 18, 2006 | 04:52 PM
Rupenthal94F150
So it sounds like to me it would just be easier to keep a 302 with my 4R70W and try to build it up and make some more horsepower. Probably cheaper too. I'm working with a fairly limited budget. Would it be possible to run a carbed 351 and find a truck with the 4R70W and get the computer out of it?
Old Jan 18, 2006 | 07:22 PM
gatesj's Avatar
gatesj
The computer from the truck with the 4R70W would expect a motor to control, I don't think it would work with a carbed setup. I think Baum Engineering makes controllers that work just to control an E4OD/4R100 (same thing basically, just updated in 4R100 form) but I don't know about the 4R70W. Lot of money either way..
SouthDakota95F150
Nov 16, 2016 12:28 AM
andrew's64
Aug 6, 2016 05:50 PM
thuli22
May 10, 2015 02:35 PM
bjmayberry2
Apr 25, 2014 05:17 PM
Rupenthal94F150
Engine Swaps
Jan 16, 2006 07:58 PM
