Where's the hazard flasher?
Old Jan 17, 2006 | 04:20 AM
Sycostang67's Avatar
Sycostang67
Question Where's the hazard flasher?
On my 85 F-250 the hazard flasher is dieing, they will work slowly for a bit, then stop altogether. I thought everything went through the one flasher, but when I remove the turn signal flasher, the hazards still work. I can feel something ticking behind the fuse box, but cant see or feel anything that looks like another flasher. Is it behind the dash somewhere?
Old Jan 17, 2006 | 06:38 AM
pknute's Avatar
pknute
The hazard circuit has a separate flasher, usually located under the dash in front of the turn signal flasher closer to the steering wheel.
Old Jan 17, 2006 | 07:07 AM
jmteam6's Avatar
jmteam6
Ford has been known to put them on the back side of the fuse box.
Old Jan 17, 2006 | 07:46 AM
220k-f-150's Avatar
220k-f-150
Check under dash, to the right of the steering column. Its usually sitting up under the dash right there. Mine was stuck up under there with double sided tape. I couldn't see it unless I stuck my head way up under there. It was stuck to the bottom of the dash.
Old Jan 17, 2006 | 07:21 PM
sandman6921's Avatar
sandman6921
Mine is on the BACK of the fuse panel. Yes the back, no idea why -- Panel is held on by two screws top left and bottom right, remove the screws and gently pull the harness and panel turning as you get slack. R&R
