Rear Lock Not Working
Old Jan 17, 2006 | 01:27 AM
rlay302's Avatar
rlay302
I've got a 2000 Limited 4x4 Excursion and the rear lock on the lift gate will not lock anymore. I mean it won't even lock with the key!
Plus where's the best place to purchase new shocks to hold up the rear lift gate?
Thanks,
rlay302
Old Jan 17, 2006 | 12:14 PM
MisterCMK's Avatar
MisterCMK
Has the lock been getting harder and harder to use over time? If so, I would try soaking it in WD-40 to clean all the crud out of there, then use a silicone lube to lubricate the lock. If it is sudden, you will need to take apart the door and take a look.
As for the new shocks, I would call around to your local parts dealers and see who will give you the best price.
Old Jan 17, 2006 | 12:58 PM
fatswany's Avatar
fatswany
Yup, like mistercmk said, I've had to do it twice now. My problem is I do 16 miles of dirt each time I take the X out. Too much dust.
Old Jan 17, 2006 | 02:04 PM
Bigjakes12's Avatar
Bigjakes12
Yep, the old oil soak trick fixed mine too.
Old Jan 17, 2006 | 07:04 PM
valvestud's Avatar
valvestud
This is a well known issue with this and the four doors. The electric actuator needs to be replaced. Do a search and you'll find instructions. Actuator is $30-35 online.
Old Jan 17, 2006 | 09:10 PM
MisterCMK's Avatar
MisterCMK
It won't lock with the key, that tells me that it is something mechanical.
Old Jan 18, 2006 | 10:39 AM
zipperhead86's Avatar
zipperhead86
Here is the link to fordpartsonline where I just bought my liftgate cylinders. Add about $8.95 shipping. http://www.parts.com/partlocator/ind...00&catalogid=1. A very easy replacement. Make sure you have something to prop the gate open while you replace them. Also, check other threads regarding the difference between the 2-wheel drive and 4-wheel drive models. That couple of extra inches clearance really makes a difference if you do the 2-wheel drive model. Rockauto had a cheaper price on the cylinders, but the part is out of stock and they are not sure when they will get more.
