Help decoding axle tag?
Old Jan 16, 2006 | 10:40 PM
Ultraboy's Avatar
Ultraboy
I've got a 2000 Excursion 4x4 with a V10 and I'm trying to find out the axle ratio. I've looked on the drivers door jam for the Axle code, but it is blank.
So I took a look at the rear axle housing for the code, and here is what it showed:
One tag showed:
S410A
7310 29L1S
The other tag talked about which oil to use.
Any idea what the numbers on this tag mean?
Old Jan 17, 2006 | 12:15 AM
Racerguy's Avatar
Racerguy
S410A is the build code.
There is probably a 3 before the 73, possibly hidden close to the bolt. That means 3.73 ratio. No L in between the 3 and the 73 means it's not limited slip.
