adding factory tach
Old Jan 16, 2006 | 07:26 PM
chrisjrosenbohm's Avatar
chrisjrosenbohm
adding factory tach
hi i have a 90 f350 460 5 speed i just got it what a mess someone put a carb engine in it it runs good but not a single gauge works well i lied the fuel gauge works i fiund the wires for the temp and oil pressure so they wont be a prob to fix my ? is the volt gauge doesnt work the needle is broke too but it doesnt even try to move what does it run off? and 2nd i d like to put a diffferent cluster in with a factory tach does it already have the wireing? if not what do i have to do to make it work? most the wires for the fuel inj. are there laying on the inner fender i want to get all thus stuff workin b4 i cut them off thanks
chris
Old Jan 16, 2006 | 07:38 PM
Popa Tim's Avatar
Popa Tim
The tach wiring should be there already, the temp & pressure gauge probably need the correct sensors to work right (ie sensors for a '90 f350) I'd hook them up first and see how well they work. Keep in mind that the oil pressure is just a dummy light that uses a needle instead of a light. If there is any pressure (above 4psi) the needle will read somewhere in the normal range. Well thats how it would work with the correct sensor at least. I'm not sure where the volt meter gets its source from.
Take care,
Tim
Old Jan 16, 2006 | 07:50 PM
chrisjrosenbohm
ok what does the tach run off? will there be a tach wire somewere in the mess of wires or does it run off the ecm i alredy bought the sensors for the oil and temp i jus have to hook them up im sure the will work because if i ground the wires out the gauge goes from 1 end to the other i jus0t dont want to buy a cluster and not be able to use it also what years are interchangable 87-? thanks
chris
Old Jan 16, 2006 | 07:57 PM
Popa Tim's Avatar
Popa Tim
it runs off the coil. I beleive its already part of the gauges wiring harness; its just not used by non-tach clusters. Otherwise its a white wire in the dash with a pink or red stripe.
I'm not sure what years are interchangeable with yours. Hopefully someone else will post that info.
Old Jan 17, 2006 | 01:09 PM
Tyler Puntney's Avatar
Tyler Puntney
I did all this crap to my pickup when i put the 460 in my 88 F-150. The easiest thing to do is get a chiltons manual for your year and make of pickup and begin looking at all the wiring diagrams in the back. i know its a pian in the a*s but that was the only way i could figure out which ones to keep and ones to cut. and you will have to re-use your factory sensors( Temp, Oil pressure, ect...) . The cluster you can get out of an 87 all the way to a 91 F-150 through F-350. Just make sure that the cluster come out of a gas V-8. (i guess a straight six might work?, but save the trouble just get it out of an V8). once you start getting rid of wires it eventually get easier. Good Luck.
bcamill
May 31, 2015 07:59 PM
6.9 diesel nut
Aug 1, 2012 04:16 PM
bishopgeer
Electrical Systems/Wiring
Apr 14, 2009 09:22 AM
Big Red
Aug 24, 2005 09:51 PM
Zebich
Feb 20, 2005 10:20 PM
