Hi,
Having a problem with my 01 F-250 truck turns over but won't start. A clicking noise can be heard while the engine is cranking. Please help. Thanks
I've gotten this in the past when I have not have enough juice from the batteries. Check your batteery terminals for a solid connection and then check the batteries themselves.
Cheap batteries will kill ya! Make sure u have good batteries and clean sufficient
motor oil.
Check oout Chuck Arnolds article on batteries at his web site: http://thepowershop.com/index.php?pr=Cheapbatteries
Nut
Check oil level. On the PSD engine your oil level/pressure is critical for the injectors to function. Of course cold weather will strain weak batteries as well. Let us know when you figure it out. Welcome to FTE!
