Where are those darn glow plugs?
OK, using the knowledge I've gained on this forum (thank you) I have determined that my "new to me" 2001 F250 needs new glow plugs. I've pulled the valve cover and I'm looking inside for the glow plugs. I can't find them!
If I follow the electrical wires above each cylinder I see a small brown box (a cover maybe) with wires going to it and nearby is a small cap with a white wire going to it. With all the high voltage warnings on the valve cover I'm a little apprehensive to take the brown box apart. Can anyone tell me where the plugs are before I shock the #$%^ out of myself?
P.S. Why I can't attach a picture on this forum?
Nut
Yes I got the PM. Thanks for the reply. However, just following the wires still left me unsure. Right now my guess is that it is under the brown box with the allen wrench bolts on it but I'd like someone to confirm that if possible.
The brown box you're seeing is the injector base, look to the right of there and find a small black wire. That's the glow plug. I needed a flashlight to find the first one but then could feel around for them after that. Of course, a shop light is never a bad idea under there either...especially for us guys with older eyes.
The gp's are smaller than you think and the wire is BURIED in there so look close. Sure wish I'd taken pics when I did mine. Maybe next time but I hope that's not for a LONG time.
Good Luck.
Good Luck.
Thank you. Thank you.
Take a look here:
http://www.frybrid.com/forum/showthread.php?t=2999
To see pictures of mine. Could it be the white wire?
Take a look here:
Take a look here:
Take a look here:
heating.
Nut
Hey chrisf, if you haven't figured this out already, you need a THIN 10mm deep socket to loosen them. A piece of 1/4 tubing works well to unscrew them once they are loosened. You won't get fingers down in there so the tubing is nice. Be sure to suction out the oil around the glow plug before you pull them too.
(Danged fancy new rigs with their WHITE glow plug wires, now I just feel like I'm missing out on all the cool stuff...I want white glow plug wires....dangit....)
Thanks for your help everyone. I worked up the courage to pull one of the glow plug boots off this afternoon. It all makes sense now. I went to Sears and got a new torque wrench and a 10mm deep socket. I've got plenty of tubing from my VO work so I think I'm ready. I'm going in after those plugs now!
