Another VIN decode needed
Old Jan 16, 2006 | 08:49 AM
UglyTruck's Avatar
UglyTruck
Howdy all, it has been a while since I have been here.
Does HOXII from St. Louis still decode vins for people???
or can anyone else do it for me please...
Vehicle: 86 F250,
VIN : 1FTHF2619GPA93454
TRANS : K
Axle: C9
Spring: 9K
This would be greatly appreciated....I need to know if some of these parts will have the correct specs so I can use this one as a donor
Old Jan 16, 2006 | 05:14 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FT
Assembly Country: USA
Make: FORD
Body Style: PICKUP
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: H
Brake System: HYDRAULIC
GVWR Class:
GVWR Range: 8,501 - 9,000 POUNDS
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: F26
Vehicle Line: F-250
Chassis Type: 4 x 4
Body Type: REGULAR cab
Engine Type - 8th Position
VIN Code: 1
Engine: 6.9 LITERS
Cylinders: 8
Fuel: DIESEL
Model Year - 10th Position
VIN Code: G
Model Year: 1986
Assembly Plant - 11th Position
VIN Code: P
Assembly Plant: TWIN CITIES: ST. PAUL, MN
Production Sequence Number - 12th - 17th
VIN Code: A93454
Prod Sequence Number A93454
Trans Code K:
Automatic C6
Axle Code C9:
No information given...
Spring Code:
No Information given...
Hope this helps...
Old Jan 16, 2006 | 11:26 PM
hoxiii's Avatar
hoxiii
Rear axle is a Sterling 10.25, 1985 and up, 3.55 ratio, limited slip, 6250 lb. capacity.
Not sure on the spring codes.
Justin
Grems4ever
Missouri Chapter
107
Jan 12, 2014 07:07 PM
Itsme7
Jan 3, 2011 09:22 PM
pintoches
Missouri Chapter
16
Jan 8, 2008 09:20 AM
Century Coronado
Missouri Chapter
199
Nov 29, 2006 06:37 PM
robsroofing
Mar 6, 2005 09:00 PM
