1978 351M Horsepower
in '77 351m hp = 161 and 400 = 173
any one have torque numbers ? i am trying to justify putting a built high output
.030 over 5.0 w/ performer carb and intake , frpp roller B-cam 1.7 roller rockers,forged internals ..stock numbers on this motor was 225hp and 300ft/lbs
in fuel injected form
Which Comp Cam (that's a huge part of this!)?
Which Holley 650?
Which timing chain set, and if applicable, what advance/retard did you use?
While maybe not a massive increase, most reports are pretty good regarding how much better the engine feels vs before the rebuild and re-camming.
Whether you get an accurate answer or not, good luck and have fun with it! Hope it's a big improvement.
Oh, and I have to ask... Do you know the proper procedure for the initial cam break-in over the first 20 to 30 minutes of the engine's life?
Sorry if you already know all that's needed, but many still don't so I wanted to make sure before anything bad happens.
Paul
71F250camper
Jul 24, 2005 12:31 AM
1big79
Nov 7, 2003 06:08 PM
