Banks Big Head Wastegate actuator
Welcome to FTE, best site around if you ask me, do some searches and a lot of reading and you are sure to go broke in a hurry with all the mods listed around here.
IF all you are doing is the actuator, the most you are going to gain is an increase in valve seat pressure from the larger spring. Very similar to this is unplugging your current waste gate by removing the red line off the end. Do a search for 6637 filter mods as well, definate improvement over stock filter for little money. Also, if you could take time to fill out the signature portion on details of your current truck setup, we will be able to help you out with questions that much easier.
I have one. Waste of money in my book. I bought it before I round the forum and realized that i can get more boost by unplugging the wastegate line on the stock actuator. That Big Head is just going ot give you more boost and quicker spool up times. Same thing is achieved by unplugging the stock part. I wouldn't do it again if I could go back. I'd just unplug the stock one.
Originally Posted by Miescha
How do I tighten the spring?
Even with the actuator disconnected it will still blow open when the drive pressure overcomes the spring pressure in the actuator. Shortening the rod increases the seat pressure and holds the gate shut a little longer.
My wastegate is pulled down with a small chain and turnbuckle...it never opens.
Originally Posted by BlackSD250
Does any of this wastegate modification have any negative effects on drivability or engine life. Also are there any noticable gains to any of this moding.
Thanks for input.
Thanks for input.
Nut
As far as engine life, I doubt it will affect it enough that the engine is going to give up. You'll probably start losing other expensive pieces first, such as tranny, TC, etc...
There are very noticeable gains. You'll have more power and torque, all the time. The turbo will spool up quicker and produce more boost, which the truck will then add more fuel to compensate, and you have more power. I'm sure I'm missing something. Some others will surely chime in to pick up my slack.
Edit: Must be too early for me. Nut beat me to a post!!
Last edited by jtharvey; 01-16-2006 at 08:32 AM. Reason: Must be too early for me. Nut beat me to a post!!
Nut
Originally Posted by PSNut
Jt..how does this mod cause quicker spool up? Seems like your just preventing the gate to open and release drive pressure=less boost. No gate opening = more boost...how does that correlate to quicker spool-up? Isn't quick spool-up a function of turbo design?
Nut
Nut
The spool-up is mainly a function of turbo desing. However, as pressure starts to build on the actuator, the wastegate begins to gradually open. Even at low boost pressures, it could just crack open slightly, letting some of the exhaust gasses by instead of through the turbine wheel. If the wastegate functioned as an instant on-off switch, then it would be a different story. Unplugging the actuator keeps the wastegate from opening as soon, even before you reach higher boost levels, so it allows it to spool up to the higher boost levels quicker. Yeah.
Nut
