a freind talked me into going to a yard sale with a lot of tools earlier today. well, i got a full size drill press, a set of R-12 gauges and 2 full in sealed boxes tanks and 1 1/2 full tank of dupont R-12, and 2 full in sealed boxes tanks of 134-A for $125. i have been doing 134-A for 10 years, but never did R-12. are the pressure readings the same as the 134-A? 40-45 lbs low side and 150-160 high side??
You need to use gauges that match the freon you are using since the connections are different between the two. Also, one pound of R-134a will read higher than one pound of R-12.
i knew as soon as i saw the prices things were going for, that there would not be much left. the ac stuff was in the shed in the far back yard, i guess everyone else thought it was the neighbors .when i saw all of that in there it was a no-brainer that it was going home with me. the $25 drill press was an added bonus, after the guy that was looking at it in the cellar realized it would not fit in the trunk of his car. i tossed the keys to the crown vic to my partner, and without a word he was gone. 5 minutes later, he pulled up in my 79 F250. we loaded the drill press, gauges, and freon tanks for me, and the 4 snap on tool box roller cabinets he bought for $20, and the $50, 120 gallon tank, 10 hp 4 piston pump, 220 3 phase air compressor.
i got over $1,500 worth of R-12 and R-134 Freon for $100,
and a $500 drill press for $25
for $70 dollars, roger got 4 tool boxes worth around $1,600 new,
and an air compressor that has to be worth at least $4,000.
The Pressures you are used to with R134a are similar to R12
You did get a bargain.
Not sure I would say that. R12 can cool well at a lower pressure than R134A can. Typicall on a R12 system there is about a 5 to 1 ratio between lhighside and low side while a system designed for R134 will be around 7 to 10 to 1 because R134 has a lower heat content so it is compressed more to enhance its cooling abilty. Also be advised the R134a is toxic and can kill is inhaled while r12 is not toxic at all in native state.
every 134 system i have ever repaired or charged has run around 3 to 1. 40-45 low, and 150-160 high. and the warmest system output i have ever had was 42º on a 95º day. my crown vic on max air has an induct temp variable of 29º to 38º
my personal mack truck is the same. average induct temp is rite around 36º.
The one in my wifes cherokee cools best when it is about 30 low and 210 to 220 high side. I have seen other native R134 systems do likewise. (in that general range depending on outside temp and humidity) Never seen a R134 "conversion" that cooled as well as they did with R12. Somw do "okay" but some do not.
R12 runs almost the same as 134 the 134 runns at a slightly higher about half a pound I have been doing this for years I prefer 12 to 134 another really good gas that mixs with 12 and 134 is 414b that way you don't have to keep several takes on hand all the time next time you buy pick a can of 414b up it works really nice
can't tell you anything about that. i have never converted a system. pre 93 has gotten the R-12 done at the shop down the highway a piece, and after 93 gets 134a done in the garage.
well the drop in gas for r-12 is 409a that is what you should really use but the cost is so high that I use 414 in almost everything that I do. Sams Club has 134 on sale right now for $195.00 while it lasts I picked up 12 30lb cans of it. Thats cheaper than my wholesaler can get it right now
sorry njf, i was not referring to your post with the conversion comment, rather to snomans post. i actually did not even see yours till just now.
i have heard about the 414b gas before, but 75 lbs of 12, and 60 lbs of 134 for $100 was a hard deal to pass on.
i figure i have enough freon in stock now to last me for life, and also leave some for the kids, or whoever gets all my crap after i am gone.
that was a really good deal that you could not pass up. are you willing to sell some of that I am willing to come get it i am only in pa. Let me know I am in need of 134 and r-12
Not hardly. R134a has a different pressure curve (higher pressures required) and it only has about 84% of the heat capacity by volume as R12 does too. Politics played a far bigger roll in the R134 standard than anything else (Dupont owns patent) because it is not really a safe product in a lot of ways as it is posionous and harmfull to environment in otherways. I can see using it in native 134 system but not for conversion as there are better solutions out there that will cool better and that are fully compatable with R12 oil which R134 is not and PAG (Polyalkylene Glycol) or POE (Ester based) is required for R134 while minral oil works fine with R12. PAG or POE is added in a conversion (POE preferable because it draws less moisture) to "bind" mineral oil from R12 to added oil to alow it to circulate properly but this also results in a slight overcharge of oil too.
414 does work well with r12 but it works better with 134 with the price of 409a I would rather use the 414b as 4091 is well over 300.00 for a 30lb can and 414 runs just a little over 200.00 for a 30lb can
the shop down the road that has done my R-12 systems forever heard about my find, and he called asking if i wanted to sell it. offered me $300 per tank, and said he would service my truck for free when i needed it again. i declined.
i guess he forgot i have 4 other R-12 equipped vehicles.
