Key Cylinder loose
Old Jan 15, 2006 | 07:59 AM
msgntsu's Avatar
msgntsu
Key Cylinder loose
Hello! I just bought a 92 F150. I noticed that the cylinder where you insert the key is loose. It will just turn in circles when the key is not present. This makes it very difficult to line up the key when you want to start the truck. Does this have to be replaced, or is there a way to tighten it?
Old Jan 15, 2006 | 09:47 AM
lv2race's Avatar
lv2race
I have the same problem with my Aerostar. Seems like the "flange" where you insert the key broke from the assembly, however, it has been like that for over 2 years. You can get a new one at your local parts house for about $15 to $20, and they take about a minute or two to replace.
Old Jan 15, 2006 | 10:29 AM
msgntsu's Avatar
msgntsu
Thanks for the quick reply. Does this mean that I will have to get a new key? Do you know how to replace it?
Old Jan 15, 2006 | 10:56 AM
someday's Avatar
someday
<a href="https://www.ford-trucks.com/forums/archive/index.php/t-450039-need%20help">need help</a>
Old Jan 15, 2006 | 10:58 AM
lv2race's Avatar
lv2race
Yep, another key for the key ring. Under the steering wheel column, you will see a small hole under the ignition cylinder. Turn your key to on, put a small allen wrench or drill bit into the hole, push a spring loaded pin and pull out the ignition switch. Install the new switch in reverse. Pretty easy.
Old Jan 15, 2006 | 07:34 PM
msgntsu's Avatar
msgntsu
Thanks for the info. I changed it today. It worked just as you said it would.
ashernaf
17
Oct 2, 2018 10:18 PM
parishboy
Dec 31, 2014 12:16 AM
FoxFord33
1978 - 1996 Big Bronco
May 8, 2014 05:05 PM
DoofusOfTheDay
13
Dec 12, 2013 05:51 PM
jas88
1997 - 2003 F150
24
Jun 22, 2009 03:01 PM
