Brakes pulling
Old Sep 11, 2001 | 09:40 PM
DantheMan's Avatar
DantheMan
Brakes pulling
Old Sep 12, 2001 | 04:14 PM
71swissaqua's Avatar
71swissaqua
Brakes pulling
Have a 71 f100. New brakes and all hardware including hoses, good alignment. When I put on brakes the truck will pull, usually to the right but sometimes to the left. I've read somewhere on this site about replacing the i-beam bushings, That it will improve overall handeling. Have not replaced them yet, everything else under the front is pretty much new. Any suggestions. Great site. Have always gotten answers here, oh yeah,is it easy to rejet a holley 600? thanks, Clint
Old Sep 12, 2001 | 05:37 PM
BB's Avatar
BB
Brakes pulling
Did the brakes pull before you did the brake job?
Primaries are easy, just remove the front bowl and metering block. Jets screw into the block. Secondaries are just the same if it uses a block. If it uses a plate you have to drill out the orifices, no screw-in jets.
Old Sep 12, 2001 | 08:32 PM
71swissaqua
Brakes pulling
Yes, they pulled before the brake job. After the job they were fine for about 1k miles then started pulling,that makes me think it's not an alignment problem, but also kind of rules out I-beam bushings too. So I guess it has to be a self-adjustment problem? I replaced all wheel cylinders, cleaned all other parts real good. New shoes of course. Is it best to remove carb from engine to change jets? Thanks for your help! It's not so bad thats it's unsafe, just real aggrivating. Thanks! Clint.
Old Sep 13, 2001 | 10:53 AM
BB's Avatar
BB
Brakes pulling
Clint, I would pull off the front wheels and check everything for leaks. Then put the wheels back on and adjust the wheel bearings. Bleed the system again and set the adjusters for a slight drag. If it still does it I would start looking at steering and suspension components.
I would leave the carb. on the engine when changing jets. The intake manifold will get washed with gas when you remove the bowls, don’t smoke! Be careful you don’t tear the gaskets, especially if it’s never been apart since new.
Barry
Old Sep 13, 2001 | 11:00 AM
beartracks's Avatar
beartracks
Brakes pulling
You might want to readjust the rear brakes. If they wore in the automatic adjusters may not be keeping them evenly and tightly adjusted. If so one may "hit" before the other.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Sep 14, 2001 | 03:35 PM
brents's Avatar
brents
Brakes pulling
[font size="1" color="#FF0000"]LAST EDITED ON 14-Sep-01 AT 04:36 PM (EST)[/font][p]Hi,
I would also look to see if any of the steering parts have worn out or have become sloppy. (Tie rods etc?) How is the steering box?
Just something to look at,
-Brents
Old Sep 14, 2001 | 04:34 PM
david_mirabile's Avatar
david_mirabile
Brakes pulling
hi i have a 72 f100 and i have had this problem for four years now. i have replaced everything in the brakesystem except for lines. i usually notice it when i haven't driven the truck in a few days. it will pull sharp to one side or the other when the brakes are applied. just curious if anyone had more info on it.
