locking hubs
Old Sep 11, 2001 | 10:16 AM
bluepony79's Avatar
bluepony79
locking hubs
Just put new brakes on the front of my 79 F150, and had to break the locking hub to get it off to turn the rotor.Where should I look to find a new set of these? I just need the outside piece where you lock the hubs in. Also, what brand do you suggest?Any info is greatly appreciated!!!
Old Sep 11, 2001 | 09:40 PM
DantheMan's Avatar
DantheMan
locking hubs
Break the locking hubs?! ouch, that's a no no. I would definately recomend Warn,(chances are that's what it had), but if you going with just one part you'll probably have to stick with the same manufacturer as the ones that broke.
Old Sep 11, 2001 | 11:43 PM
DrFord's Avatar
DrFord
locking hubs
If you are talking about the plastic **** that you turn, well then my friend you are fighting a lossing battle. this happened to me and I couldn't find them anywhere, not even specialty shops or dealer. I had to go to a junkyard and take them off of an old truck there.
Old Sep 12, 2001 | 03:05 PM
Irondale90's Avatar
Irondale90
locking hubs
www.4wheelparts.com:80/product2.asp?imseqn=721&occlass=WARHUBS&cat=LH
check these out. I have a set on my 77 f-150. way better that the originals.. this is the part nuber you need WAR20990.
Old Sep 14, 2001 | 04:01 PM
the wall's Avatar
the wall
locking hubs
Old Sep 14, 2001 | 06:16 PM
bluepony79's Avatar
bluepony79
locking hubs
The casing that holds the **** you turn is what I had to break to get off. Two of the screws that hold it on were rounded off, and have you ever trying to drill these???? Impossible!
