exhuast temp
Old Jan 14, 2006 | 07:12 PM
jasonlasvegas's Avatar
jasonlasvegas
exhuast temp
I know this has been covered before but What is the difference in max temp From post turbo to pre turbo?
Old Jan 14, 2006 | 11:11 PM
yamahonda41's Avatar
yamahonda41
From what I have read on here about 200 degrees cooler post turbo.
Old Jan 15, 2006 | 08:49 AM
Don-T's Avatar
Don-T
My personal experience from having gauges both pre and post turbo on one truck was an eye opener. When cruising down the highway I would see 200* or less difference. With a load (12K camper) I could easily see 500*+ difference on an up hill run or accelerating onto a freeway. At idle after the engine has warmed up to normal; the pre turbo temp can be lower than the post turbo temp until the turbo cools down. If you are using a "chip" the pre turbo might be a better choice. If you are towing with a stock engine the post might be better.
Old Jan 15, 2006 | 06:08 PM
yamahonda41
That is very good info Don-T. I am on my first diesel and tow in Florida heat with stock engine/exhaust and so far no chip or tuner. I was thinking about a single gauge pre-turbo but now you have me scratching my head.
Old Jan 15, 2006 | 06:31 PM
fzrider998's Avatar
fzrider998
I've been reading this forum for several years now. And I drive a full stock '04 F250 CC, PSD6.0.
Through all the articles I've read about people putting EGT guages on their trucks, I have yet to figure out what the point is. Is it merely to know what the temperature is? What corrective action are you going to take? Shut down the truck?
I realize that after putting a chip on truck, you might want to put guages on to see EGT, but again, why? Just so you can see that it is x degrees? A stock truck under full load probably has extremely high temps. I grew up in the anthracite coal regions in PA and living on center st. in Ashland, I could watch the big rigs grunt their way up the mile long hill that was Route 61/Center stree, and you could sometimes see the flame tips at the top of the stacks!! So, yes, deisels are hot...
So, someone, please enlighten me about what the point of the guage is, other than to tell what the temp is...
Old Jan 15, 2006 | 07:08 PM
yamahonda41
I personally just like knowing how hot the engine is running to keep from damaging the turbo, etc. Also on shutdown here in FL at least if you have been towing a heavy load and stop for whatever reason the turbo is still extremely hot. I have read that the bearing life will be greatly reduced by the oil that is in/on the bearings breaking down due to the high temps.
Also if you are towing heavily loaded up a long hill you can back out of the throttle or shift gears if necessary to keep below the magic numbers that are pretty well known for causing damage to the engine components.
Besides that I just like gauges and bells and whistles
Old Jan 15, 2006 | 08:10 PM
fzrider998's Avatar
fzrider998
thanks, yamahonda...kinda what i figured. I know myself, even from running extended time on the highway, i like to let it cool down for 5 mins or so, just cuz i know the turbo is probably cooking pretty good.
so, what ya ridin? yamaha, honda? both?
Old Jan 15, 2006 | 09:50 PM
Milwaukee,WI's Avatar
Milwaukee,WI
Anyone got a picture of where they put the thermo couple when they went post turbo?
I got the pre-turbo gauge and tranny temp, but now I want to add a post turbo gauge. I'm thinking post turbo will be even easier then pre-turbo was.
Can I Drill into the down tube just past the turbo? How far past the turbo do I have to go to be safe?
Old Jan 15, 2006 | 10:07 PM
yamahonda41
We have a Yamaha Warrior, Honda 300EX, Honda 250EX and I ride mostly a 1989 Honda CR125 I paid $100 for and rebuilt. Ugly but fast and almost as much fun as my 6.0 PSD
