Ok still larning here can someone help me?
where is my Idle Air Control Valve on
my van.going to take it out and clean it
haveing idling problems.
I was reading here that might be my problem
Sits right on top of the engine and easy to see when you raise the hood. Held on my two small bolts and has a two-wire electrical hookup. Take the bolts out, unhook the wires and it should come right off. Do it easy and you should be able to reuse the gasket. Size-wise, it easily fits in the palm of your hand.
The IAC for the 3.0L sits on the Throttle Body, under a plastic cover. That plastic cover is held by three plastic push-on pins. The IAC is held by two bolts, and has a two pin connector on the back side. After cleaning, you should replace the gasket before putting it back on.
