Computer trouble
Old Jan 13, 2006 | 09:46 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Computer trouble
I just added a second computer to the family room. One modem to a router that goes to both computers. Nothings changed as I can log in the FTE and send messages with old computer but not with the new computer. The FTE tells me i'm not logged in, when I try to log in it says "wrong name or password entered" Any help is welcomed, puter dumbo me thanks. Carl.....=o&o>.....
Old Jan 13, 2006 | 10:25 PM
Cravin's Avatar
Cravin
Two words "enable cookies"
Old Jan 14, 2006 | 06:27 AM
924x2150's Avatar
924x2150
Is the second computer running a different e-mail address? FTE also recognizes your e-mail address, and compares it to your user name and password. If you are logging on to the internet with the same e-mail address
user name, and password it should work.
Old Jan 14, 2006 | 07:37 AM
Dungeon_Master's Avatar
Dungeon_Master
Other then not loging into FTE can you enter any other sites neededing a name and password?
If it's just FTE. I would say it was your cookie settings and or you mis typed the name or password.Or your logged into FTE already on the other computer and it's blocking you. I can access FTE through my wifes computer and she has a separate ip and email
Old Jan 14, 2006 | 09:55 AM
rusty70f100's Avatar
rusty70f100
What you need to do is either:
A. Go back into your e-mail and dig up your password, or
B. Use the forgot your password thing to reset your password. It should be e-mailed to you, then write it down. After that, log in as normal on both computers.
After that's done, enable cookies so you dont have to log in every time you visit.
Old Jan 14, 2006 | 03:03 PM
jake00's Avatar
jake00
do you mean ip address?
I'm guessing they are the same as they both go through the same router.
Rustyford has the right idea
Old Jan 14, 2006 | 03:26 PM
"Beemer Nut"
I found that I had to get a new password for FTE, Hotrod, Oilguy and all other forums to get back in and now I can be on the same forums at the same time with both computers. Panic set in when I couldn't get into FTE on both computers for my daily "fix". Thanks for the help.
.....=o&o>.....
150ford
Nov 7, 2010 12:02 PM
cjben
15
Dec 28, 2007 06:35 PM
68torino
Apr 3, 2005 09:29 PM
