351m to 400
Old Jan 13, 2006 | 05:41 PM
351m_torque's Avatar
351m_torque
351m to 400
how much torque and horsepower will i gain by converting my 351m into a 400?
thanks in advance
Old Jan 13, 2006 | 07:31 PM
danlee's Avatar
danlee
I simulated a 351M motor (+0.030") with 9.0:1 CR, a Comp Cams 255DEH cam, 600 CFM carb, and headers and got:
Torque = 394@2000 RPM, peak Torque = 397 @ 2500 RPM, peak HP = 308@4500 RPM.
Then I changed the stroke only and got:
Peak Torque = 456@2000 RPM, and Peak HP = 303@4500.
The reason that the 400 torque and HP drops off faster than the 351M at high RPMs is due to the lower VE as a result of the carb size and head flow limitations.
The result is 62 ft-lbs more torque at low RPMs. More HP can be obtained by improving the head flow, and increasing the carb size.
