ticking
Old Sep 17, 2001 | 10:16 PM
thelonerangerxlt's Avatar
thelonerangerxlt
ticking
Old Sep 19, 2001 | 11:11 PM
slothshady's Avatar
slothshady
ticking
hey my truck(77' I6) is making a ticking/sucking sort of noise and it is missing out a bit...
when i plug up the pcv valve it stops... the valve is not broken i went and bought a new one and it does it to. and ideas?
AaRON
http://www.geocities.com/azzzholezz/i6.jpg
Old Sep 20, 2001 | 06:22 AM
jowilker's Avatar
jowilker
ticking
Replacing that whimpy I6 with a 390 would be a great place to start. :-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Sep 20, 2001 | 09:16 AM
dfisher1's Avatar
dfisher1
ticking
You got a vacuum leak. The PCV valve is a designed leak. By blocking it off your compensating for a leak elsewhere. There is another possibility. If you have a leak in your block then your PCV valve will pull to much air. Do you have a massive oil leak? Are your power brakes working O.K.? If the pedal is rock hard, you could have a lack of vacuum. Check your Choke. Often they leak due to the absence of the thermal wand which is supposed to attach to the exhaust manifold.
Got to go. Good Luck, Have Fun,
KingFisher
