1978 - 1996 Big Bronco
Clunking from Drivetrain...
Old Jan 18, 2006 | 12:03 AM
greybullit's Avatar
greybullit
re_fill, I think you might be right, we could have the same problem. Becuase like you said about the shifting at low speeds, I too have the similar abrubtness in between shifts. However, mines not so much a "clunk," but more of a harsh shift, by that i mean, no noise just a sort of jolt...any ideas anyone???
Old Jan 18, 2006 | 12:09 AM
re_fill's Avatar
re_fill
jpjahn: that's exactly what mine is doing. It clunks at a dead stop when I shift from forward to reverse, but NOT EVERY TIME. It will also clunk when I let the gas off, like to coast or slow down. I hope it's not the rear-end and will try the fix streetgang mentioned above. But do you think the play in the drive shaft is ok (like I said above, the shaft has play almost a third of a revolution). The U-joints are tight and the trany is tight.
Old Jan 18, 2006 | 12:18 AM
jpjahn's Avatar
jpjahn
If it really is backlash it can go for a long time before anything will happen. Unless you treat it bad. Minde doesn't clunk too noticably when I shift from forward to reverse.. I mean there is some clunk, but its not bad. It clunked more before I replaced the Tranny mount, so mabey you could check to see if that is broken... I was planning on taking my truck on a long trip, so I took it to a rear end doctor...hehe... just so he could check to make sure it wasn't going to explode on me. If you had some place nearby, call and ask if they would just take a look.. They don't have to tear anything apart to check the general condition of the rear. One mechanic rode with me for a few minutes while I demonstrated what happens. Both of the guys narrowed it down to backlash in the rear, and a stretched transfercase chain. And they both did it for free.
Old Jan 18, 2006 | 01:05 AM
re_fill's Avatar
re_fill
I had my son sit in the truck and change gears (drive to reverse) and there was no movement in the tranny or any of the drive-shaft u-joints. It all seemed to come from the diff. Can it be adjusted to eliminate the play?
Old Jan 18, 2006 | 01:48 AM
jpjahn's Avatar
jpjahn
Well, you would adjust backlash if thats it. But like i said before, the mechanic said mine would last another 50,000 miles at least with no problems.
Old Jan 18, 2006 | 09:03 AM
poffutt's Avatar
poffutt
Guys, you say your u-joints are tight. My 89 clunked just as you guys are mentioning. I changed all my drive shaft U-joints and the clunk is gone. It was amazing how tight it made the drive train feel. Anyway I found the best way to check the U-joints is to jack your rear wheels off the ground, put her in neutral to relieve all stress on the drive train. Crawl under the car and spin, shake and wiggle the drive shaft at each u-joint. If you have not relieved the stress on the drive train, then a u-joint will still be stressed and feel tight.
Old Jan 19, 2006 | 10:43 PM
dwoodler's Avatar
dwoodler
We once spent three weeks and hundreds of bucks to a ford 1/2 ton that had the same symptoms. After a new pinion and ring and re-adjustment there was still clunking coming from the drive train, and that was from an actual shop (not my garage). My '89 Bronco clunks about the same as yours grey and refill and it's been doing that for a few thousand miles. My '88 did it too. I just figure it's a Ford thing....Nothing has grenaded on me yet. If you do figure it out make sure to let us know here so we can all fix this problem too.
Old Jan 20, 2006 | 02:42 AM
greybullit's Avatar
greybullit
Alright, so today when I was heading to work, I was taking a turn and I heard a clunk and then the truck started vibrating like crazy, and ideas? My immediate thought was engine or tranny mount...
Old Jan 20, 2006 | 02:48 AM
jpjahn's Avatar
jpjahn
I have no idea really, but did you ever check your tranny mount???
Old Jan 21, 2006 | 02:08 AM
greybullit's Avatar
greybullit
So i figured it out, it turns out I had a crack in my drive shaft, replaced it and everything is working fine now, wierd how that works out, thanks for all the input though!
Old Jan 21, 2006 | 06:53 AM
cjbronco's Avatar
cjbronco
glad you figured everythign out
Old Jan 27, 2006 | 10:49 AM
RVBfordman's Avatar
RVBfordman
Clunking in drive shaft
The problem is in the two piece drive shaft. It needs greasing. There is a special high speed grease that ford has that you can use. I simply pull the rubber dust cover back and force the grease into the splines. The best approach is to drop the shaft pull it apart and give it a good greasing but I have had success forcing the grease into the splines.
Old Jan 29, 2006 | 07:32 PM
  #28
jamie1's Avatar
jamie1
I have a 2000 Excursion 4X4 V10 with 117,000. The clunking started on mine. I took it to a 4wd shop and found out the 4 U bolts that the rear end mounts to. They were a little loose, 4 new U bolts and it went away.
Old Jan 30, 2006 | 07:06 AM
  #29
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome jamei1 to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 10, 2006 | 07:42 PM
  #30
re_fill's Avatar
re_fill
Thanks For That Insight
I was this (!) close to re and re my differential. As a last resort, I did exactly what you suggested, until my fingers and thumb were numb (....sorry honey, not tonight, I was working on the drive-shaft...?). I will probably break down and drop the whole shaft and do it properly, but in the meantime, after re-packing the splines it slowly went away (the horrendous clunks). Thanks again. I won't ask why this worked as the U-joints, tranny mounts and the slip yoke seemed tight, but it did. I owe you a coke.
