Sponsored by: Auxito
Loud Squeak
Old Jan 20, 2006 | 07:38 AM
highboy390fe's Avatar
highboy390fe
I am going to be putting new brakes on today anyway, so I will check everything out again.
Old Jan 21, 2006 | 12:38 AM
Johns9163's Avatar
Johns9163
Ok, I finally broke down and fixed "the squeak. Took all of 30 minutes, including getting the tools out and consuming one Corona while I was as it. Removed the swingarm to frame bushings, two bolts on each side at the frame, 13mm. Bushings are split so they slide right off the bar. Cleaned all of the "stuff" that had accumulated in there, some of it had crusted. Lubed with a light coat of grease, and put them back in. Squeak gone. New bushings are about $8.00 each. F150's came with two different swaybar diameters in the front, 27mm and 31mm so measure before ordering. Most parts houses will have to order them. If the squeak comes back, I will just stick new ones in. This is more of an experiment than anything else...
Old Jan 23, 2006 | 08:03 AM
highboy390fe
I fixed mine this weekend, also when i put some new brakes on. Thanks for the help.
Old Mar 29, 2006 | 09:45 AM
bladesxxx's Avatar
bladesxxx
Thanks Everyone, I have sprayed everything I could imagine that would make the squeaking but it keeps coming back. I will try removing the bushings and never seizing them.
adamstewart7
1997 - 2003 F150
Jul 24, 2012 08:04 PM
mikesmayhem
Feb 25, 2010 09:19 PM
1974f250
Aug 11, 2009 08:48 AM
rx7gtr07
1983 - 2012 Ranger & B-Series
Oct 1, 2006 04:28 PM
Imaddog
1997 - 2003 F150
Apr 18, 2004 04:18 PM
