2.9 oil pump priming
Old Jan 13, 2006 | 10:45 AM
fyre82's Avatar
fyre82
Question 2.9 oil pump priming
Probably a dumb question but here goes anyway . . .
How can I prime a 2.9 oil pump without 1. an old distributor shaft,(don't have one), 2. buying a 35$ tool that I'll only use once.
I have the engine on a stand and I want to do this before installation. I've read the technique of turning the engine, installed, without the coil attached to do it, but, I would prefer to get it primed up without that.
I don't think that I have a thin wall socket that will fit to attach it to a drill.
I guess I could install the distributor and turn the engine by hand, but that doesn't seem like I could get enough rpm to get the pump primed and oil into all the bearings and lifters that way.
The engine is a remaufactured and I have spent way to much time and $'s to have it go T.U. on the initiall start up.
Thanks in advance.
Rich
Old Jan 13, 2006 | 02:43 PM
dernst's Avatar
dernst
I don't like the idea of just unpluging the coil wire and turning the motor over either. I don't see how you are going to do it without the tool or an extra distributor shaft.
When I did mine, I installed the shaft from another distributor that I had and turned it with a 90* drill motor. I did it while the motor was on the stand and once again after it was installed.
If you lived closer, I would loan you mine. I'm in S. CA.
rustoleum82
Sep 2, 2016 08:04 AM
fordmania
Nov 25, 2012 02:08 PM
dimerol
Oct 28, 2011 10:30 PM
lilpig88
May 14, 2003 06:11 AM
onewaymike
Nov 30, 2002 02:02 PM
