No Fire
Old Jan 13, 2006 | 01:26 AM
bedman's Avatar
bedman
No Fire
93 4.9 Sometimes after engine warms up, it will crank over fine but get no spark.It will fire after 3-4 attempts. Also there is no power to fuel pump when this happens.I Replaced pick-up in dist. and elec.ignition module.Didn't work. Had truck diagnosed at local NAPA repair garage and thier answer was replace fuel pump!! Pump won't work without power,thanks for nothing. Need help.
Old Jan 14, 2006 | 02:25 AM
Truckin Bob's Avatar
Truckin Bob
Sounds like a bad ignition switch.
Not the part that the key goes into....but the module under the steering wheel.
Bob
