I Have A 99 Superduty Crew Cab F350 4x4 With A 6in Suspension Lift, Took It To The Front End Shop Told Him That The Truck Pulls To The Left And He Says It Looks Like It Pulls To The Right. Thats What The Specs. Say. Does Anybody Else Have That Promplem?
Welcome to the site!
Did you have it aligned? If its a good front end shop they should fix it don't you think.
Ball joints wheel bearings and everything else under there is probably worn out or on its way. Its a 99 with a lift and tires, its gonna fall apart..Unless of course you already replaced all the front end stuff.
