accelerator pump gushing gas
Old Jan 12, 2006 | 06:09 PM
76 F-150 390FE's Avatar
76 F-150 390FE
Cool accelerator pump gushing gas
i have a holley 4160 600CFM when i put it to the floor it doesnt spray the gas in the bores it just pushes its way out around the diaphragm and leaks onto the manifold. i rebuilt the carb becuase it was haveing the same problems and i thought the diaphragm was just dry rotted (which it was) but now its like the passage is blocked.
Old Jan 12, 2006 | 08:28 PM
Ranger GT2's Avatar
Ranger GT2
Yep, it sounds like you have something in the passages of your carb. When you rebuilt it did you blow all the passages out with compressed air?
Old Jan 12, 2006 | 08:36 PM
76 F-150 390FE
its not a blocked passage i found out. i just pulled it and it is squrtin it into the bores and gushing out. i had a feeling that the screws were bottoming out and not getting a good seal on it so i added and extra washer and it stopped it from coming out the sides now it just dripps down the center where the arm gos in. so the only thing i can figure is that where the plate and the shaft go through the diaphragm is not seald right so i put silicon on it and im gonna try it out tomorrow. i have heard people say dont use silicon on carbs. but if this dont work then who cares? it would be time for a new carb. im not going to let a gas leak on the engine go becuase i dont want to see my truck going up in flames.
maddogjohnson
Mar 11, 2017 10:28 AM
PapaBearYuma
Mar 5, 2017 10:44 AM
1918ALF
Sep 15, 2014 03:14 PM
mechelement
Jun 4, 2014 11:39 PM
brnltjo
Aerostar
Nov 8, 2007 12:42 AM
