Which tranny line is the inny and which one is the outy
I installed a aftermarket radiator in my truck which has the trans cooling ports stacked vertically instead of horizontally on the bottom like the old rad. Anyway on a C-6 which trans line is the outgoing and which one is the return? I understand that the outgoing should attach at the top of the rad and the return at the bottom. Thanks
Dan
Dan
Originally Posted by loveoldtrux
It is a straight through connection, but I'd let the input go to the top of the ports - letting gravity assist the flow of ATF. Forcing it in the bottom and then UP to the top would not be a good idea
it might just matter
If you are running your aftermarkert cooler in series wiyh your factory in radiator you want the cooler to be after the radiator one .If you do not do it this way the radiator will put heat back into the fluid.Unhook one factory line start vehicle briefly BRIEFLY!!!!!!!
& see which way fluids goes if from pressure side it will shoot out a foot or so.f shoots from line then you use other line to run to cooler if it shoots from radiator then run to cooler then back to tranny. Up here in the GREAT WHITE NORTH if you do not run through the radiator cooler sometimes tranny will act funny for a mile or 2 in cold weather.this is because the radiator warms up fluid a little if you bypass the radiator cooler up hetre takes a little rollin to get fluid up to temp. Remember every 20 degrees down to 180 degrees doubles tranny life.
