The coffee can
Old Sep 24, 2001 | 07:34 PM
jagabom's Avatar
jagabom
The coffee can
I have a 77 F150 with a 400. What is the purpose of the coffee
can located right beside the battery? It seems to be hollow inside.
Jim
CYWG
Old Sep 24, 2001 | 08:08 PM
F100_CA's Avatar
F100_CA
The coffee can
Does your truck have a/c? I had an old Granada that had auto climate control and there was a vacuum reservoir (more like an apple juice can)that maintained vacuum to the control head. Could this be your coffee can? You didn't indicate what if any lines were coming from the can.
Got my curiousity up...
Old Sep 24, 2001 | 08:17 PM
FTE Ken's Avatar
FTE Ken
The coffee can
Its a vacuum-assist chamber for the brakes.
Ken Payne
[img src="/dcforum/User_files/webmaster/usaflag.gif" valign=top align=left] Ford Truck Enthusiasts Admin
Old Sep 24, 2001 | 08:30 PM
jagabom's Avatar
jagabom
The coffee can
No air conditioning. There are 2 vacuum lines going to this can.
Your right, it looks more like a juice can.
Thanks
Jim
CYWG
Old Sep 25, 2001 | 11:14 AM
Irondale90's Avatar
Irondale90
The coffee can
these are usually fuel vapor vacum chambers. If one of the lines goes from the can back to the fuel tank it is used to suck fuel vapor into the carb to be burned. The can is to be sure fuel splash that gets sucked down the tube will evaporate in the can and not flood the carb or intake with fuel. Can you tell where both of the vacum lines go? This will give a better idea of what this vacum chamber is used for in your truck.
Old Sep 25, 2001 | 02:17 PM
laptopgeek's Avatar
laptopgeek
The coffee can
It's the Charcoal Canister - pop the top off and you can see the charcoal that lost it's ability to filter fuel vapors years ago. I re-located mine back to the rear of the truck to show off more of my engine chrome. The cannister uses the same crystaline charcoal your fish tank uses....
The LaptopGeek -----
1974 White F100 Custom Fleetside
460 bored .040 over & C-6 automatic 2WD
Lunati cam, L&L Headers / mounts
Holley Avenger 770CFM & Edlebrock RPM
Plush black leather 40-20-40 bench seat
38 gallon JC Whitney fuel tank
Old Sep 25, 2001 | 02:27 PM
FTE Ken's Avatar
FTE Ken
The coffee can
Seems there's two definitions floating around. There is indeed a charcoal canister but early trucks with power brakes had vacuum canisters between the power booster and the manifold.
Ken Payne
Old Sep 25, 2001 | 05:59 PM
royisme's Avatar
royisme
The coffee can
On my '76 F-150 there looked like there was a large pork and beans can or something, which was the charcoal canister. Part of the smog crap...
Old Sep 25, 2001 | 06:27 PM
F100_CA's Avatar
F100_CA
The coffee can
Jim
I would have to agree with Ken that this is a booster for the braking system. I thought about the charcoal cannister when I replied before but with only two lines coming off of it and the juice can shape this is unlikely. The charcoal cannister in my 78 (can't be much different than your 77) has three lines and is a plastic container that in no way resembles a juice can.
A thought...if your as lucky as me your local library may have the factory manuals for your truck. The main branch here in Halifax has the complete 5 volume set for my old truck. They are invaluable for sorting out odd questions like this. So try your local library, you never know.
Old Sep 25, 2001 | 07:22 PM
brown 4x4's Avatar
brown 4x4
The coffee can
OK guys, I've seen one on a 74 F-250, but my 79 and 86 don't have them. However, a friend's 96 F-150 has one too. I can't remember what was coming out of it, but the truck did have a separate charcoal canister. The only pattern I've seen is the one's with them (the cans) have air conditioning, so it might have something to do with that?
Old Sep 25, 2001 | 08:13 PM
Crazy_John69's Avatar
Crazy_John69
The coffee can
It' to give your engine that extra boost of energy in the morning.
Old Sep 25, 2001 | 09:07 PM
beartracks's Avatar
beartracks
The coffee can
Does your battery set on the passenger side up front? Mine used to have a "gallon juice can" black in color under my battery. It was the "charcoal canister" I think. Several small lines to carb and tank.
I have no vacuum reservoir for the brake booster (straight hose from the intake manifold) but do have a small ball vacuum reservoir that will move the heater door motors after the engine is off if you change the control settings.
If you had the canister it would be long passed working anyway but pay attention to the lines that might be disconnected. One goes to the tank!
Good to see the flag!
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Sep 26, 2001 | 10:39 AM
BB's Avatar
BB
The coffee can
LOL John I like your sense of humor!
Old Sep 26, 2001 | 04:34 PM
beartracks's Avatar
beartracks
The coffee can
Old Jun 25, 2007 | 08:32 PM
shooer's Avatar
shooer
I'd like to revive this thread. My "coffee can" has 3 tubes coming off it, no hoses. The smog guy says it needs to be hooked up,very important! The mechanic I use says it is a vacum resevoir for the air conditioner. I guess I'll have it hooked up anyway so I can pass my smog test. I would really like to know for sure exactly WHAT this can is for.
ps 1977 150 400ci
Don
